Old 04-25-2009, 08:38 PM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
CG Lock = next best thing to a harness
I've had harnesses in a few of my past cars, and I was sad to see that the Yaris doesn't yet have a good harness bar to safely mount a set with. The flat OEM seats and body roll were making cornering tiring having to brace myself all the time :D
A while back I read about the CG Lock (http://www.cg-lock.com/index.html), which is basically a little clamp that attaches to any OEM lap belt and "locks" it onto you. I picked one up today from Bavarian Autosport in NH (49.99) and have been using it all day. I must say, I'm very impressed.
The install takes a minute or two at most, and it works exactly as advertised. You sit down, buckle up, then cinch the waist belt tight. Before you know it you're pretty well locked into your seat and no longer have to brace as much around turns. With your core locked down I found that I didn't really miss having my chest locked in like a traditional harness (though that has other advantages). And when you're done with it you pull the little lever and it releases. You can also remove it quickly too (though I may just leave it on, it's nice driving with it). It's also SCCA legal I believe.
In all, for the CG Lock, it's awesome!
Old 04-25-2009, 09:50 PM   #2
yarstar
Drives: 2008 Absolute Red HB
Could you post a pic? This could be what I'm looking for.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-25-2009, 10:08 PM   #3
schleppy
I love momentum.
schleppy's Avatar
Yeah, I'll try and grab one tomorrow. To be perfectly honest, you won't get much more from a pic taken by my than you will from going to their site. They have a lot of good pics and videos there.
Old 04-26-2009, 04:40 AM   #4
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
seems cool, but kinda expensive... seems like a $25-$30 part to me (altho from the pictures/video it's a bit hard to judge its workmanship/materials)
Old 04-26-2009, 02:36 PM   #5
schleppy
I love momentum.
schleppy's Avatar
$49 is not a lot for what it does. It's a very well made piece, the company backs it 100% and it has been pretty rigorously tested by them and many, many users.
Old 04-26-2009, 02:57 PM   #6
yarstar
Yep. This is exactly what I need. I didn't want a whole harness, but I needed to be tightened into the seat better. I be getting one of these this week.
Thanks for making the thread. Once again, my knowledge is expanded by Yarisworld.com.
Old 04-26-2009, 03:42 PM   #7
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Word. I had one of these on the yaris. Get yourself a $300+ harness and spend another $300+ on a bar, or get this. It's not quite the same as a 4-5 point harness, but it's better than the OE seatbelt.
Go to their website. On a side note, it also works well for seniors who need to be secured on a visit to the doctor, hospital, etc.
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 04-26-2009, 10:26 PM   #8
yarstar
Got one coming. Thanks again.
Old 04-26-2009, 10:35 PM   #9
schleppy
I love momentum.
schleppy's Avatar
No problem!
Old 04-27-2009, 10:21 AM   #10
hmmmm just an idea, would it not be possible to use a second one of those to hold the shoulder belt tight too?
Old 04-27-2009, 10:26 AM   #11
schleppy
I love momentum.
schleppy's Avatar
I seriously doubt it.
Old 04-27-2009, 09:48 PM   #12
Yaris-x
Yaris-x's Avatar
Drives: 2008 Yaris HB
why spend money all I do is put the seat all the way back move the belt fast so it locks and put the seat foward again till it is tight it has held me in for two years with no problems
Yaris-x is offline   Reply With Quote
Old 04-27-2009, 10:10 PM   #13
schleppy
I love momentum.
schleppy's Avatar
1.) That's ghetto
2.) That probably takes longer to do than it does to adjust the CG-Lock.
Old 04-28-2009, 08:13 AM   #14
Yaris-x
Yaris-x's Avatar
It takes two seconds pull then slide and I am $50 richer
Old 04-28-2009, 08:16 AM   #15
schleppy
I love momentum.
schleppy's Avatar
Whatever floats your boat man!
Old 04-28-2009, 08:39 AM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
you can buy a full 3" 4point harness for around $100... worlds better than a CG lock.. :D
Old 04-28-2009, 08:55 AM   #17
schleppy
I love momentum.
schleppy's Avatar
Yes, and you also have to spend a few hundered dollars on a harness bar to mount it safely.
Old 04-28-2009, 08:56 AM   #18
Tamago
Tamago's Avatar
Drives: UZJ100
even if you fasten it to your rear seat bar it's still safer and more secure than a CG lock.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Headlights harness slvryaris Cosmetic Modifications (Exterior/Interior) 13 07-19-2007 12:19 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 04:19 AM
