Old 05-16-2015, 10:24 PM   #1
RWJC
Drives: 2014 Yaris LE hatch
anyone running 18s?
I was wondering if anybody was running 18s on thie yaris. How did it afftect your MPG, drive, handeling?
Thanks in advance. Running 18s on mine. The 215/35-18 are almost within 1/4 of an inch the same diameter of the stock, so speedo and all is still dead on, and it looks good.
Here is before & after...
after:
it has not been lowered or modified suspension.
RWJC is offline   Reply With Quote
Old 05-17-2015, 12:29 AM   #2
willieG
Drives: 09 hb 2nzfe m
fuel used around and extra L per 100km around town. highway is about the same
Handling/breaking in the dry is much better.
lower top speed/acceleration compared to stock 14's
[IMG][/IMG]
willieG is offline   Reply With Quote
Old 05-17-2015, 08:52 AM   #3
RWJC
okay, thanks...
I noticed the lower MPG, so I was trying a CAI, but it keeps triggering the darn MAF sensor, and it is air tight....
what size tire do you run?
Old 05-17-2015, 09:43 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The CAI internal diameter has to be the same as stock.
Old 05-17-2015, 10:07 AM   #5
willieG
215/35/18 same as you.
I'm not sure how to fix the CAI problem. But I've drilled some holes on the lower section of the standard airbox which makes it louder like having a pod filter on :/ and with some piping to the front for a 'cold air' intake.
I did do a few acceleration tests from 50km/hr between a couple of markers on the road before and after adding the 'speed holes' to the airbox. ended up getting around 6-9 km/hr better after
Old 05-17-2015, 12:42 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
A stock 1nz with a CAI won't really honestly net you much for better FE. You will spend more money to put a viable solution on than you will save for years. 18s are just plain heavier. You pay to play. I ran my 18s on mine for about 2 years. Loved the look, but was at almost 60lbs per corner! No way in hell I would have done it without being boosted. As for top speed well mine were 225/40/18 so I actually was able to hit around 125mph while the ECU had no idea so when the fuel cutoff hit at 118 that is what it thought I was going.
Old 05-19-2015, 12:50 AM   #7
RWJC
thanks for all the replies. The seat feel is better HP & Torque with the CAI....getting a 2" MAF tube to resolve.
Old 05-19-2015, 03:34 AM   #8
Thebigwicks
Drives: 2008 lowered yaris on 17's
Which CAI are you running? I'm using the K&N typhoon with out any issues what so ever. Also stanced on 17"s. Pretty low I guess so it's hard for me to give you an accurate mpg and handling write up.
Thebigwicks is offline   Reply With Quote
Old 05-19-2015, 08:27 AM   #9
Bluevitz-rs
2" is too small.
I'm fairly certain the exact size is 2-⅜". But just do a search on the forum to find it.
Sent from my iPod Touch
Old 05-19-2015, 09:07 AM   #10
aspro
I ran 17's on my echo hatch a while back and I hated it. Completely ruined the handling, acceleration and braking of the car. Sold them and went back to stock. Rims size and weight is so crucial to the overall performance of the small cars. You don't have much power to play with, so any weight and or diameter changes are felt instantly!
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 05-19-2015, 09:08 AM   #11
aspro
And those (op) 18's look heeeeaaaaavy!
battery light stays on but running fine galactus Mid-Atlantic 13 08-15-2013 10:50 AM
zage turbo in and running but engine stalls at idle! what could it be?! DKN-YARIS Forced Induction Forum 5 06-05-2013 11:43 PM
Rear running lights not working 2007 yaris spectra DIY / Maintenance / Service 6 12-18-2011 11:20 PM
Relay Wiring for DIY LED Daytime Running Lights (DRL) zuberio DIY / Maintenance / Service 20 07-07-2011 09:02 PM
I'm running 18's ,should i bother lowering my car? PICS Inside dinamix Photo-Video-Media Gallery 15 08-16-2009 08:27 PM
