Old 08-10-2009, 08:35 AM   #1
dinamix
Drives: magntic grey
I'm running 18's ,should i bother lowering my car? PICS Inside
should I bother lowering the car ? Im looking to drop around 2.5inches ..
I will be sacrificing ride comfort and major rubbage if i do. half of me says yes to lowering the other half says no.
can anyone with photoshop please help lowering my car?
I just wanted to see if it would make a big difference. running 18"s take some of the wheel gap away
TIA
dinamix is offline   Reply With Quote
Old 08-10-2009, 03:30 PM   #2
TRDMarty
Stace is EVERYTHING!!!
LOWER IT & You'll love it even more.
You'll find yourself always looking back at your car when walking away.
Even more than you probably already do.
Old 08-10-2009, 04:04 PM   #3
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
It looks badass... But you are looking at major rubbage like you said... are you sure you can handle that?
Its a Chao!!!
Old 08-10-2009, 04:53 PM   #4
supmet
Drives: 2007 4 Door Yaris
errr rub isn't the right term for a 2.5 inch drop on 18s... more like grind, or destroy your wheel wells/tires. A reasonable 1.5 inch drop would probably only have slight rubbing.
Old 08-10-2009, 05:15 PM   #5
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
I ran Tanabe DF's with my trd 18's i had minimal rubbing on the inside plastic liner, but it all depends on your offset and tire size.
my specs:
18x7.5
offset: 42mm
tires: 215-35-18
springs: tanabe DF's (1.6-1.8?)
stock shocks and struts
Old 08-10-2009, 06:18 PM   #6
DandiDani
DandiDani's Avatar
my hubby got 18's on his 07' sedan and its lowered. It
does look a lot better. sometimes rubs...but he says
it cuz we need diff tires and once we get diff tires we
should be okay
Old 08-10-2009, 06:28 PM   #7
^ true and some camber bolts wouldn't hurt either.
Old 08-10-2009, 07:40 PM   #8
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
not so much into the camber, I just hate the way it looks with the wheels leaning or tilted all I need is thinner tires and I guess I should be good
Originally Posted by sw07gt
Old 08-10-2009, 07:46 PM   #9
ChinoCharles
Drives: LB
Dude, that color is HOT. Haven't seen that on a liftback yet.
Old 08-10-2009, 08:11 PM   #10
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
No true one bit bro I have 18"x7.5 wide with 215/35 tires and stock camber and honestly from a stock measurement my from is about -5/6" lower in the front and at least -7" lower in than stock in the rear , granted Im on coilover , Im just saying a Hard "stanced" yaris can be done with very minimal damage(if any) and you're only gonna rub the fender liner .
Old 08-10-2009, 10:12 PM   #11
06silveryaris
Drives: 2006 yaris
I have 17's on a 2" drop and it only rubs when full turn
06silveryaris is offline   Reply With Quote
Old 08-11-2009, 03:13 AM   #12
M4One
Drives: 2007 Toyota Yaris Hatchback
I've got a question for you. Do you plan on driving your Yaris in the winter? I remember last winter in Vancouver and how I had trouble at times going through the snow in the side streets stock. My buddy has a lowered Yaris and he pretty much told me not to bother lowering mine because of that reason. With Echo's photoshop job, it does look pretty good. Maybe for others that are lowered they had an easier time driving through the snow.
M4One is offline   Reply With Quote
Old 08-11-2009, 04:42 AM   #13
dinamix
Originally Posted by echo_hrs View Post
Cheers
wow..that was quick..thanx dude your awesome!
Old 08-11-2009, 04:47 AM   #14
dinamix
i'll have my spare 14" winters tires(blizzaks)on by then..ground clearance might be an issue..other than that my tires should be good..
yeah it was an 09 canadian color..pretty common with the other models..magnetic grey mettalic is the name
Originally Posted by DandiDani View Post
Attachment 27140
should be okay
Im runng 35 series.. i think your hubby has 50 series on his..he should get some thinner tires
Ill have to stay away from u-turns..lol
you know me so well..lol
Old 08-11-2009, 11:51 AM   #15
drop it like it's hot.. Unless you like the wannabe mini-Escalade look... I've got 18's and coilovers:
Yes, rubbing is a small price to pay. But it's really not that often while driving "normally", and there always some solutions to reduce it if it gets out of hand
Old 08-16-2009, 07:27 PM   #16
DandiDani
DandiDani's Avatar
18's
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
may be emigrating to china, should I sell, or give car back, also running on spare. waylandchin General Yaris / Vitz Discussion 29 08-17-2009 06:38 PM
Custom Paint Almost Done (pics!) Prohibit Photo-Video-Media Gallery 11 11-23-2008 10:32 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
