![]() Drives: 2012 Yaris SE Join Date: Jun 2012
Rusting away..
Have a 2012 White SE. The hatchback is rusting all along the chrome strip above the license plate. Is anyone else having an issue? Its obviously holding water hence the rust.
Thanks |
would be under warranty go get it looked at the dealer there body shop will fix it...i have see few Toyota's with same problem mainly Venza and some Corolla....all covered under rust warranty protection ....and yes white looks like main color on all..odd maybe bad paint or something.
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
I'll have to verify tomorrow, but I'm pretty sure I've got a few rust spots in the same area on my 2012.
![]() ![]() ![]() Drives: Gray Join Date: Jun 2012
Around the license plate, can you take a picture ? I have to check mine, maybe I overlooked that spot, considering the winter has been so cold, with only the odd warm days.
Sorry, I was mistaken. I looked this morning and I couldn't find any rust spots on the chrome. I did find a few small rust spots on the sheet metal to either side of the license plate, however.
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Are these little tiny flecks of rust in the paint?
If so, this happens on all cars, but you can actually see it on white cars. A claybar will remove it. I've owned four white cars, and they all get this. It's often referred to as environmental fallout. However, if it's not this, I got nothin'. :D
Subcompact Culture: The Small car blog |
#7 | |
![]() Drives: 2014 Yaris Icon + 1.4D4D Join Date: Mar 2010
There is a TSB in Europe regarding this issue with a specific repair procedure to follow to ensure the rust once repaired does not return.
The fault is a chemical reaction between the chrome coating on the trim and the fixing holes on the tailgate, the modification involves repairing the tailgate and fitting a modified trim along with insulators between the two. The UK bulletin ref is BO-0086T-1213 |
Yes. Unless this is something more than just environmental fallout. Could you post a pic?
The 1st generation Matrix had a sweet spot for rust at the rear door handle on the drivers side .
Mine is a 07 sedan.. and this is what is rusting around the chrome trim. I took out the trim for these pictures.
Wow. My 2005 xB (in 2006) was rusting at a door weld on the driver's side. A number of other owners had the same issue.
Does Quebec use salt on its roads?
#13 | |
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
i had 2 rust spots in the left side in the middle of the paint, has been repaired under warranty. i have also developed another right under behind my toyota emblem.... |
![]() Drives: 1991 Buick Century Custom Join Date: Jul 2013
White Yarii develop rust easily, blazing blue ones will have their clearcoat start to peel... are there any other problem colors I should know about before I buy one?
$10.25/hr frying chicken
2012 as well, just showing signs of rust above the license plate
Geesh , that's a big hole
. Any water getting into your trunk ?
#18 | |
I removed the chrome trim to clean the area and protect it a little bit from rusting more. It's not bothering me much since my car is not the cleanest anyways.. |
| **SAFETY RECALL!! 06-07 YARIS HB & SEDANS** | slvryaris | DIY / Maintenance / Service | 83 | 09-30-2012 01:25 PM |
| Yaris design oversight... | abattle | General Yaris / Vitz Discussion | 54 | 09-24-2010 05:52 PM |
