Old 07-25-2006, 04:46 PM   #1
abattle
Drives: 2007 Yaris Sedan
Yaris design oversight...
I have had my 07 yaris sedan for about a month now and use the a/c everyday. I was looking at how clean the engine compartment was one day and noticed something that worried me. The a/c condensation drain pipe drips right onto a bolt and washer for the suspension/steering. I have only had it a month and already the washer was rusted badly! I had to change this immediately. I just took a piece of rubber hose and extended the drip away from everything to prevent the bolt (and who knows what else) from rusting....I feel much better about it and just wanted to pass this on to as many as I could. Thanks, abattle
abattle is offline   Reply With Quote
Old 07-25-2006, 04:53 PM   #2
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Thanks for the tip!
Idjiit is offline   Reply With Quote
Old 07-25-2006, 05:37 PM   #3
fearturtle44
Drives: S Flint Mica
Nice find. Could you tell us exactly where to find this drain pipe in engine compartment?
Thanks.
fearturtle44 is offline   Reply With Quote
Old 07-25-2006, 06:34 PM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Any pics of exactly where this is?
Old 07-25-2006, 06:35 PM   #5
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Yes that would be nice seeing how I only have 600 miles on mine
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-25-2006, 07:15 PM   #6
swng
swng's Avatar
Drives: 06 3-dr auto RS
Any idea about whether the same happens to the HB?
I think Toyota should do a recall to fix the cars affected.
swng is offline   Reply With Quote
Old 07-25-2006, 07:38 PM   #7
Chaad32
Chaad32's Avatar
Hmm...I just realized that he had a sedan. I went to look at my L/B and it wasn't like that. Maby thats why.
2007 Liftback
Blazing Blue
Old 07-25-2006, 08:40 PM   #8
swng
swng's Avatar
Thank you! You have just saved me some time which should have been used for checking out my own HB. Still feel sorry for the sedans.
Old 07-25-2006, 08:54 PM   #9
rstb88
rstb88's Avatar
Drives: Silver Hatchback
I was about to say cause I'm about to breech 5000miles and that means my suspension components are about ready to go if they are rusting like that. And make sure you get a replacement galvanized bolt. my a/c doesn't get that cold. do you think its possible that because it was a showroom vehicle it wasnt properly charged with r134a
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 07-25-2006, 08:59 PM   #10
MacMaster761
Five-Star General
Drives: 07 Silver Streak Mica
Send a message via AIM to MacMaster761
ummmmm, pictures of the pipe, and what type of hose did you use... thanks
MacMaster761 is offline   Reply With Quote
Old 07-25-2006, 10:41 PM   #11
paeko73
Drives: Yaris "S" Sedan
Will the dealership prevent the mentioned problem by doing the hose extension free of charge? Or will they tell you that it's "ok", and will fix it when it actually rust out like the original poster's sedan?
paeko73 is offline   Reply With Quote
Old 07-26-2006, 08:10 AM   #12
abattle
I doubt they will fix it for free(but I didnt ask)...Mine is located on the passanger side just behind the engine, way down at the bottom. I just slid a piece of hose aprox.5 inches long OVER the small hose. I think the inner diameter of the hose I put on was 1/2 inch(it fit snugly but I put silicone glue on it anyway, making sure NOT to obstruct the water flow)I will try to get a pic but not sure when I can get it in here, sorry...
Old 07-26-2006, 09:19 AM   #13
fearturtle44
On my sedan, I looked and saw the water hitting the ground but could not see location of pipe. But the "nuts and bolts" still look good to me.
Pics would be nice.
Kevin
Old 07-26-2006, 04:41 PM   #14
weeze-dog
Drives: 2002 Ford Focus ZX3
A/C is dealer installed...you never know what you are going to get....
weeze-dog is offline   Reply With Quote
Old 07-26-2006, 04:43 PM   #15
Chaad32
Chaad32's Avatar
I don't think so buddy
2007 Liftback
Blazing Blue
Old 07-26-2006, 06:35 PM   #16
Chris07LB
Chris07LB's Avatar
Only if it didn't originally come with A/C from the factory...... Is that what you ment to say?
Old 07-26-2006, 06:49 PM   #17
Chaad32
Chaad32's Avatar
A/C is standard. And he is from Ohio.....it is definately standard in the US
2007 Liftback
Blazing Blue
Old 07-26-2006, 06:55 PM   #18
Chris07LB
Chris07LB's Avatar
You know that... I know that.... I was asking if HE knew that.
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
