Old 01-20-2016, 08:10 PM   #1
Dragonslayer182
Teal Squealer
Drives: 07 Yaris Sedan
07 Sedan driver side window roller hard to move
Recently, my 07 Sedan's window roller has been acting strange. Sometimes, it takes a lot of force to move it, and it gets stuck for a bit. Other times, though, it rolls just fine. Is there any way to fix this?
Dragonslayer182 is offline   Reply With Quote
Old 01-24-2016, 12:50 AM   #2
Dragonslayer182
Teal Squealer
Anything? This is starting to become a real pain...
Old 01-24-2016, 09:49 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
try spraying the window's edges with silicone spray.
My brother had bought a 7th gen celica that had the drivers window motor replaced because the thought it was dyeing. All it was, was a lack of lube in the window tracks. Sprayed it and the window went up and down like new.
Old 01-24-2016, 10:09 AM   #4
nortonfb
Drives: 2007
I would pop the door panel off and look for what's binding.
You don't say if this manual or power. Look for insulation in the crank or on the track. Something that would interfere. You can lube the crank with grease, not much.
White lithium is good but anything will work. Also, look at the arms of the window mech for any bending, check the rotation points.
nortonfb is offline   Reply With Quote
Old 01-24-2016, 10:20 AM   #5
Bluevitz-rs
a petroleum bassed lube will attract dust and dirt.
Use silicon as it repels water and dust.
Driver's side window part help yours_falsely DIY / Maintenance / Service 4 03-20-2012 06:02 PM
driver side A/C vent blowing hot air Yaross DIY / Maintenance / Service 4 12-05-2011 08:51 AM
side markers Sedan deemllgn Cosmetic Modifications (Exterior/Interior) 1 03-02-2009 09:44 AM
