Old 12-05-2011, 05:04 AM   #1
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
driver side A/C vent blowing hot air
Sirs,
I know somebody here already had same problem with one A/C vent blowing hot air (side vents on the dashboard, infront of cup holder). I tried searching but no luck. Probably using the wrong keywords
In case you know the thread, please post the link, otherwise, kindly advise.
The problem:
My driver side A/C vent recently started blowing hot air while the center and passenger side vents are blowing cold air. It occurs when the temperature knob is set from halfway the cold setting (blue colored) up to the start of hot setting (red/orange colored).
When set on the warm settings, all vents are blowing warm/hot air.
when set on halfway down to full cold settings, all vents blowing cold air.
Appreciate all your replies. Thanks!
Yaross is offline   Reply With Quote
Old 12-05-2011, 06:29 AM   #2
This the one you're thinking of?
http://www.yarisworld.com/forums/showthread.php?t=35602
Old 12-05-2011, 06:36 AM   #3
Sounds like a different issue through. It sounds like the OP's blower mix door is not straight in the airbox or maybe is binding on one side, since it is fine all the way open and all the way closed.
Old 12-05-2011, 07:30 AM   #4
Yaross
Yaross's Avatar
Yes Sir!!! Thanks!
Thanks, I will try to remove my dash over the weekend and see if I can find something. I hope my A/C is not starting to die out on me.
Old 12-05-2011, 07:51 AM   #5
Yaross
Yaross's Avatar
Yes Sir!!! Thanks!
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 100 06-20-2019 12:59 PM
Anyone here trim off the sides of the weathertech vent visors? marlondog Cosmetic Modifications (Exterior/Interior) 9 02-11-2010 11:36 AM
Driver side Seat Belt gwasabi DIY / Maintenance / Service 13 05-09-2009 06:45 AM
Side impact air bags... do I have them? chumpster Cosmetic Modifications (Exterior/Interior) 6 04-27-2009 07:04 AM
Driver side foglight trim gwasabi Willing to Buy by private party 3 03-03-2009 03:11 AM
