Old 05-07-2009, 05:33 PM   #1
gwasabi
Drives: 07 Blazing Blue LB
Driver side Seat Belt
I have harness's installed and was wondering how do I get rid of the Driver side warning light and Chime all together. Is it just a "splice the wires and your good to go" method? if so which wires? I on;y see two and I've read about if you disconnect it or something it will stop the car from starting or something. THank you in advance.
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-07-2009, 05:42 PM   #2
Can't you just latch it from behind the seat?
Old 05-07-2009, 08:37 PM   #3
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Bypassing safety features - think of it as evolution in action.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 05-07-2009, 09:39 PM   #4
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Yah, Darwinism in Action...
Old 05-07-2009, 10:50 PM   #5
MadMax
MadMax's Avatar
The first thing he said was that he had a harness installed, which means a four-point or something like this...
(Great visual aid, eh?)
...that is much safer than the standard seatbelt.
Now, all I can think of is to put one of the old seat belt ends into the slot; but he is asking about doing a little electric mod. Can someone help, instead of posting responses without even reading his first post?
If there is any "evolution" or "Darwinism" in action here, it is simple reading comprehension and situational awareness will greatly increase your chances of survival!
Old 05-07-2009, 11:58 PM   #6
WolfWings
WolfWings's Avatar
Go badger a Toyota dealer, it's in the manual if you rummage that they can disable the seatbelt chimes.
Old 05-08-2009, 11:48 AM   #7
TLyttle
TLyttle's Avatar
... and put a bit of tape over the light...
Looks like we have to cover this subject about every 2 months. Too bad the Search function doesn't work.
Old 05-08-2009, 01:52 PM   #8
1stToyota
1stToyota's Avatar
Keep it simple; swipe a seatbelt extension from your dealer. Owner's manual states that they will be provided to you for free; got mine for free just days after I bought my car.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-08-2009, 02:10 PM   #9
supmet
Drives: 2007 4 Door Yaris
Does your magical tape stop the chime too??
And there are lots of threads on this subject... for the PASSENGER seat belt
And I don't know if he wants to be sitting on top of an extension?? I wouldn't. Maybe he could finagle it behind the seat, but I'd still take it to the dealer to see if they'll just disable it.
Old 05-08-2009, 02:36 PM   #10
Goose
Car Geek
Drives: Yaris Liftback
If your dealer is willing to do so, the chime can be disabled without any cutting or disassembly. Disabling the chime is done by plugging in a proprietary scan tool into the car and selecting the appropriate setting. Should take about fifteen minutes.
Kevin
'07 Blazing Blue 5-speed liftback (sold)
'08 Black auto liftback (sold)
'09 Carmine Red auto 4-door liftback (sold)
Goose is offline   Reply With Quote
Old 05-08-2009, 02:49 PM   #11
1stToyota
1stToyota's Avatar
Don't hook the belt into the extension.
The extension fits into the buckle/latch and tucks neatly between seat and console. Hardly know it's even there and doesn't ever have to be enabled and disabled by the dealer once it's installed...about a 5 second project; easiest solution there is.
2008 Scion xD
Old 05-08-2009, 09:39 PM   #12
TLyttle
TLyttle's Avatar
Once the service tech plugged in the scanner, it took 30 seconds to disable the chime for both the driver and passenger seats. It beeps 5 times then shuts up. No real complication there...
Old 05-09-2009, 06:44 AM   #13
gwasabi
Actually I figured it out and did a switch mod. I got a switch that I can either turn the seatbelt signal on or off with. I just modified my Aux input jack in the center console and stuck a on off switch in there. Looks pretty mean if you ask me hahaha
Serious Business...
Old 05-09-2009, 06:45 AM   #14
gwasabi
and yea its the same harness's hahahahaha takata's are sexy
Serious Business...
Driver seat TEHxFALLEN V1.2 General Yaris / Vitz Discussion 4 01-21-2018 04:29 PM
Drivers Side Seat Belt Won't Retract redyaris DIY / Maintenance / Service 8 08-07-2014 10:37 AM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
