![]() ![]() Drives: 1nzfe Join Date: Jan 2016
E85 Big Dog Pump
Walboro 460 E85 1NZ-FE Fuel Pump. Drop in and run wild.
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
to run E85?.....all you need is larger injectors, E85 converter plug and ecu....dont need fuel pump
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
That comment is almost hilarious. Yes you do need a better bigger pump, especially under boost. And spark plugs? That's the least of my worries. And to just drop in some larger injectors from another car is not the correct answer either. I've run E85 for 5 years and your where I was back then.
under boost, lol
So when do we see the set up run? I've so far only seen stills of your engine bay and parts...
#6 | |
Rabbito, your too new to know this but this IP user has been banned multiple times on this forum and other forums because of his attitude. Do a quick user search for xbgod. He has been working on this car since '10. Longest build with a huge budget ever.
E85 needs to be euthanized. Using alcohol in gas raises food prices for the poor around the world and lowers our mpg.
![]() It's a lose-lose proposition.
#9 | |
| Water Pump, Do it myself or pay someone? | cutchin | DIY / Maintenance / Service | 30 | 02-20-2016 12:09 PM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 11:41 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 01:33 PM |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 09:04 PM |
| So how do you like the BIG SMILE on the 07 Sedan???? | Ziv | General Yaris / Vitz Discussion | 3 | 02-03-2006 12:12 PM |
