![]() ![]() Drives: 1nzfe Join Date: Jan 2016
That comment is almost hilarious. Yes you do need a better bigger pump, especially under boost. And spark plugs? That's the least of my worries. And to just drop in some larger injectors from another car is not the correct answer either. I've run E85 for 5 years and your where I was back then.
| Water Pump, Do it myself or pay someone? | cutchin | DIY / Maintenance / Service | 30 | 02-20-2016 12:09 PM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 11:41 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 01:33 PM |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 09:04 PM |
| So how do you like the BIG SMILE on the 07 Sedan???? | Ziv | General Yaris / Vitz Discussion | 3 | 02-03-2006 12:12 PM |
