Old 04-05-2016, 02:58 PM   #1
Motomariner
Drives: 2007 yaris
High Mileage Maintenance
New poster here. Glad for any help from more experienced mechanics/members.
We have a 2006 Yaris with 140k miles on it.
Have done very little to it other than Oil, Brakes, and Tires.
Had to replace spiral cable early on, later reimbursed after Toyota recall. Also a seatbelt failed.
Any recommendations from Members for service items to keep her running?
Brake fluid? Transmission fluid flush?
Anything particular to watch out for for?
Motomariner is offline   Reply With Quote
Old 04-05-2016, 04:16 PM   #2
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
good ideas. also consider inspecting brakes and greasing brake caliper pins (with proper grease only).
spark plugs should've been replaced by now too.
jack black is offline   Reply With Quote
Old 04-05-2016, 04:46 PM   #3
tmontague
tmontague's Avatar
Search the forum for the control arm bolt issue. I'd recommend replacing the bolts now before it's too late.
I agree w/ Jack Black, clean and re grease the brake sliders on the caliper and re adjust the star nut on the brake shoes so you only have 2 or so clicks on your e brake, makes a big difference is brake bite when stopping.
The other thing i'd do is replace or inspect the exhaust donut gasket that connects the mid pipe to the exhaust header. When you're down there replace the 2 spring bolts as well. This will ensure you avoid further problems down the road if you ever need to replace the parts due to failure
Old 04-05-2016, 05:49 PM   #4
Manual or automatic?
Old 04-06-2016, 04:44 AM   #5
Motomariner
Drives: 2007 yaris
Automatic....
Old 04-11-2016, 01:36 AM   #6
eiriksmil
Drives: Yaris
Low maintenance cars.. Do a coolant change.. Brake fluid flush. And spray the underside with Fluid Film if it isn't undercoated come winter. Rust is what will kill it if you live in the north east, not anything engine related.
Oh and change the trans fluid if you haven't but don't flush it.
eiriksmil is offline   Reply With Quote
Old 04-11-2016, 07:01 PM   #7
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
It's nice that you don't have to worry about changing a timing belt/chain with these cars.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
-Mileage Thread- -Log your mileage, year, model, color, any problems here... Kal-El DIY / Maintenance / Service 322 07-20-2016 10:07 AM
Amazing Gas Mileage .. way too easy. edmscan Fuel Economy Forum 9 07-19-2012 06:36 PM
Another oil question - high mileage goliath1812 DIY / Maintenance / Service 9 06-29-2011 05:25 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 03:14 PM
