Old 06-24-2011, 01:59 PM   #1
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Another oil question - high mileage
I currently use synthetic 5W-20 in my 2007 sedan. Now as it gets older, and I put more miles on it (currently has 85,000 miles) I've been thinking of trying out Amsoil's 0W-20. Should I still do that, or should I stick with the heavier weight for the "increased age" of the motor?
goliath1812 is offline   Reply With Quote
Old 06-24-2011, 07:29 PM   #2
Happy Little Pony
Drives: 2007 Yaris HB
85,000 miles isn't really very high mileage for a modern engine. I don't know that your going to get any great benefit from the switch, since you live in a warm weather location, but it shouldn't hurt anything either.
Happy Little Pony is offline   Reply With Quote
Old 06-24-2011, 08:26 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
just stick with synthetic oil your using.. u will be fine
Old 06-24-2011, 11:23 PM   #4
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
As all ready been addressed, 85k is not high mileage at all especially if you were the person to put on those miles. I can see two benefits right away, you might want to up your intervals and/or slightly better gas mileage.
Going from a syn to another syn can never hurt.
Old 06-25-2011, 03:29 AM   #5
ilikerice
ilikerice's Avatar
http://www.yarisworld.com/forums/sho...t=35115&page=2
Check this recent thead out if you havent already done so yet. The OP is not the same question, but the tread got off topic and you will see what your looking for there
Old 06-26-2011, 08:30 PM   #6
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Amsoils 0W-20 is an excellent oil and I would have no reservation at all about using it. (In fact I have a case downstairs, lol. )
It is a "heavy" 0W-20 with an HTHS of 2.8 so likely at temp it is probably heavier than the 5W-20 you currently use.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-28-2011, 07:53 PM   #7
bankrobber
Drives: 2007 Yaris Hatchback
I have been running 10-30 synthetic in my yaris. I just bought half a case of Shell synthetic 6 quarts for 18 dollars at BJ's wholesale club. I almost bought the 20 weight byt couldn't remember if it used that weight. Should I use the 20 weight? I have 113k miles and I am at 11,000 miles on the oil. Usually change at 7,500 but been low on cash.
Oil still looks good and right up to full mark
Old 06-28-2011, 08:51 PM   #8
ilikerice
ilikerice's Avatar
Id stick with what you got. 10-30 is fine. just stick with synthetic and it will last you forever. Your not burning oil yet so thats a good sign your valve stem seals are still good. Not hearing any ticking or knocking, you will be fine
Old 06-29-2011, 03:28 PM   #9
R2D2
Crazy Oil Sniffer
R2D2's Avatar
I agree 10W-30 (especially syn) works fine. Dino 10W-30 might not be my first choice in extreme cold but otherwise would be fine also.
R2
-The Fitful One
Old 06-29-2011, 05:25 PM   #10
goliath1812
ok, just got some amsoil 0w-20 in today, along with a royal purple filter. i'll see how it goes for the next few thousand miles...
Question about a changing oil level Goose DIY / Maintenance / Service 3 11-02-2010 10:32 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
OIl Viscosity Question nimith DIY / Maintenance / Service 3 04-07-2009 07:29 PM
Noob engine oil question. Do I HAVE to use 5w-20? (closed) yarisugi DIY / Maintenance / Service 5 11-09-2008 05:34 AM
