Old 04-16-2009, 07:42 PM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Oil drain plug gasket question
I just did my first oil change on the Yaris. It has got to be the easiest oil change I've ever done, and I've done a lot of em.
My only question is about the oil drain gasket. I tried (gently) to scrape it off, but it didn't want to budge. It looked like a metal gasket with a blue papery coating on it. It felt very permanent. Needless to say I left it on and installed my new magnetic drain plug. It felt like it made a tight seal and so far no leakage.
Am I crazy? Should I have got out a razor and tried to get the old gasket off? Did they switch to a "permanent" gasket in 09?
Thanks all!
Old 04-16-2009, 08:09 PM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Its called a crush washer and its supposed to come off.
Old 04-16-2009, 08:23 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Yeah sometimes they are hard to remove. If you left it on your okay for 1 or 2 oil changes. Then you may develop a very slight oil leak if you dont replace it with a new gasket. I just buy a bunch of cheapo paper gaskets. And replace them every time.
BTW thumbs up on the drain plug. Whenever i do a oil change i always see a little bit of metal debri on the magnet. Will greatly extend the life of your oil pump. I also use a giant neoprene magnet on the bottom of my oil filter. That way i just toss the filter at the oil change and stick the magnet on the new one. For just a couple of bucks i figure its worth the investment if it extends the life of your motor.
Old 04-16-2009, 09:00 PM   #4
schleppy
I love momentum.
schleppy's Avatar
I'm well aware of what it's called, I've just never seen one with a colored felt-like material on it. Usually it's just an obviously (mildly)smushed metal washer. This one was thick and didn't look compressed at all.
I'm not going to lose any sleep over it, I just wanted to double check with the collective mind on here :D
Thanks all!
Old 04-16-2009, 09:09 PM   #5
YarisSedan
Trick i use is take a screwdriver and put it at a angle where the washer is and tap it gently and it flys off.
Old 04-16-2009, 09:58 PM   #6
schleppy
I love momentum.
schleppy's Avatar
I'll give it a go at the next change. Thanks!
Old 04-16-2009, 10:01 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
ive never seen this before, Ive done most of my own oil changes.
Old 04-17-2009, 05:35 AM   #8
jambo101
jambo101's Avatar
Thanks all!
You could ask your dealer about it.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Magnetic Oil Drain Plug PetersRedYaris DIY / Maintenance / Service 13 11-16-2010 06:41 PM
motor oil drain plug washer xpeteyjtx DIY / Maintenance / Service 13 12-30-2008 01:27 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
