Old 02-16-2007, 08:00 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Magnetic Oil Drain Plug
What do people think of these? I've used one on many of my Toyotas and like them but wonder if they're nessasary. Anyone else use them?
Old 02-17-2007, 06:56 AM   #2
esquiva
Noypi ako!
esquiva's Avatar
Drives: 07 S Sedan 5-Speed M/T
what kind did u use and how did u benefit from using it?...any downside?
Nagka-anak sina boy at nene, isang lalaki at isang babae. binata't dalaga na sila...
Nene jr.: tay, peram naman ng kotse o...
Boy Bastos: sige pero isang kondisyon. mag-ano muna tayo.
Nene jr.: tay meron ako ngayon e. blowjob na lang kita.
Boy bastos: o sige.
pagkatapos ng blowjob...
Nene jr.: tay, bat lasang tae yung etits nyo?
Boy bastos: ah ganon ba? hiniram kasi ng kuya
mo kanina yung kotse e!
esquiva is offline   Reply With Quote
Old 02-19-2007, 01:11 PM   #3
PetersRedYaris
It's a fully machined aluminum plug with aluminum crush washer. That’s the original plug in the package as the magnetic plug is installed in my Yaris. They’re supposed to reduce engine wear by attracting and holding on to any metallic particles to small to be filtered out by the oil filter. I have never had the amount shown in the picture stuck to the plug, perhaps because Toyota’s are built so well, but do have some indicating the filter doesn’t catch everything.
Almost forgot, I owned several brands of these and some are complete crap. This one is actually made very well.
Old 02-19-2007, 01:38 PM   #4
PetersRedYaris
This is what it looks like, but silver.
Old 02-19-2007, 09:19 PM   #5
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
where to purchase?
Go4th is offline   Reply With Quote
Old 02-19-2007, 09:31 PM   #6
Go4th
Go4th's Avatar
I found this.
http://www.carparts.com/autoparts/Pr...Ntt=oil+magnet
Old 02-19-2007, 09:57 PM   #7
PetersRedYaris
Originally Posted by Go4th View Post
Yes, those also are supposed to be good.
Old 02-19-2007, 09:58 PM   #8
PetersRedYaris
where to purchase?
Honestly, ebay is easiest. Should be about $10 plus shipping.
Size is the same for all Toyotas, I actually kept mine when I sold my Tacoma.
Old 02-19-2007, 10:02 PM   #9
Go4th
Go4th's Avatar
ill take a look... thanks
Old 11-12-2010, 01:04 PM   #10
jstantherprsn
Drives: 01 Toyota Echo
just buy a bunch of ceramic magnets from ac moore. I placed 3 ontop of each other and set them on the plug. Then I placed 3 more near the plug. I've been driving and they haven't fallen off. I also have a few on the oil filter. Its a 4 dollar solution.
jstantherprsn is offline   Reply With Quote
Old 11-12-2010, 02:23 PM   #11
severous01
arent neo-mags awesome...i mean at harbor freight you can get some tiny mega-magnets for .99. and you get like 10 of them. i have some on my fridge...and i cant pull them off without a tool or sliding to the edge of the door...tehy're that strong.
just put a few on the oil filter and leave them alone...tehy wont fall off, and if they do you lose .10 per unit??? come on. you can also stick them on the fuel rail and make your own 'mystery fuel economy booster' that people sell on tv for like 50 bux. if it works in oil, it'll work on fuel too.
Old 11-15-2010, 10:19 PM   #12
ibanezjeepguy
Drives: 2010 Meteorite Liftback
haha fuel magnets, funny.....
I do have the filter-mag slapped on all my vehicles including our new yaris and the less small metal particles floating around suspended in the oil, the longer the oil will last and the less friction drag associated across the bearings which can possibly add to slight increases in acceleration & gas mileage though most probably wont notice any short term benefits, long term engine wear will be the sure test.
drain plug magnet is a great way of telling just what is floating around in suspension, but the filter-mag is the only real way to capture it before its force circulated to all critical bearings
ibanezjeepguy is offline   Reply With Quote
Old 11-15-2010, 10:50 PM   #13
severous01
hahaha...you can always glue some to the bottom of the fuel tank. how cool would that be to see some metal on them when you go to change the pump in about 350k miles...actually, that would suck.
any way...yeah it was a gimmic. you can take the magnet off a pair of earphones with noise canceling (where they take the wire, loop it around a magnet, and close the magnet on the wires) and make the same thing. jsut a series of magnets in a circle that clips together around the fuel line. supposed to make the atoms align a certain way and vaporize better out of the injectors. ha...'tornado' anyone???
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Fumoto Oil Drain Valve Toddhata DIY / Maintenance / Service 47 02-21-2007 03:46 PM
About to do my first oil change Kaotic Lazagna DIY / Maintenance / Service 32 01-15-2007 04:00 PM
