Old 03-29-2016, 02:01 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Low fuel warning and E ain't really Empty
wanted to see how much gas is really left at E
it took 9.6 gallons in the 11.1 tank
from the manual ...
Low fuel level warning light
Indicates that remaining fuel is about 1.7 gal. (6.3 L,
1.4 Imp.gal.) or less.
 Refuel the vehicle.
the warning light came on at 3 miles remaining
so i have ~1.5 g left at indicated empty -- very close to the manual
easily 50 miles
good to know
did you know the small "XP104" designation on the speedometer is spark plug type?
Old 03-29-2016, 05:42 PM   #2
bronsin
bronsin's Avatar
Yes good to know!
Also gtk the fuel pump is cooled by the gas in the tank and if you re running with no gas in the tank the fuel pump isn't being cooled!
Old 03-29-2016, 06:10 PM   #3
justanotherdrunk
Drives: 2016 SE
Yes good to know!
gtk
not running at all if there is no gas in the tank
Old 04-10-2016, 06:51 AM   #4
apmatzen
apmatzen's Avatar
Drives: Toyota Yaris 2015 1.0VVT-i T2
Almost the same on mine...about 10 litres left in the tank.
Still gasoline for about 90-100km...
The tank is 42L in the european. (If I remember correct)
Toyota Yaris 1.0VVT-i T2
apmatzen is offline   Reply With Quote
Low Fuel Warning Light NYC-SE Third Gen Yaris General Discussion 18 08-18-2014 04:53 PM
Low fuel warning light not working? Lerico Third Gen Yaris General Discussion 3 08-06-2014 05:27 AM
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 08:28 PM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
