Old 08-05-2014, 12:05 PM   #1
Lerico
Drives: Yaris 2012
Low fuel warning light not working?
Hi all,
When does the low fuel warning light comes on?
The range on the onboard computer shows 31km left, but there is still no warning light.
Does the low fuel warning light comes on when you turn the key to "accessory"? Like, the phase where you test whether all lights work.
Thanks!
Lerico is offline   Reply With Quote
Old 08-05-2014, 12:20 PM   #2
mr_miles
Drives: 2013 Yaris
It should come on relatively soon, I believe it comes on when the remaining miles is around 15. Also, im pretty sure the low fuel light doesn't come on when you start the car.
Old 08-06-2014, 03:18 AM   #3
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
I've not got as far as the low fuel warning light yet but I have found the computer estimate of range remaining is very pessimistic. Which I suppose is better than the alternative!
Recently I went to the lowest fuel since buying the car, the miles remaining showed 33. However, the tank had capacity for 31 litre, so 11 litre still remaining. Therefore sufficient fuel left for around 90 miles to empty. The fuel gauge appeared more accurate, still indicating a 1/4 tank remaining.
mrpj is offline   Reply With Quote
Old 08-06-2014, 05:27 AM   #4
mr_miles
Drives: 2013 Yaris
In my experimenting with the gauges accuracy, when the gauge hits E you still have almost 2 gallons left it seems. Mine does go far below the empty mark, too. I always reset trip meter A and go by it instead. If the gauge didnt use a float it would be more accurate, but I dont know of any other methods lol.
"5 Driving Myths That Cost You Money" PETERPOOP Fuel Economy Forum 10 05-24-2011 10:20 PM
How do you reset the TIRE PRESSURE WARNING LIGHT penny09 DIY / Maintenance / Service 3 09-26-2010 02:53 AM
Rear left indicator light not working jinxor DIY / Maintenance / Service 3 04-25-2009 03:38 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 01:44 PM
