Old 03-19-2007, 02:35 PM   #1
Kitt
Kitt's Avatar
Fuel low light issue
So i was trying to change the factory bulb for the fuel low lamp with a LED one and the problem started: The LED was on all the time even do there was fuel on the tank, installed back the stock bulb and there was no light on it. Tested the bulb and it works fine, tested the contacts for the bulb and i got 12v as usual. Did i fried something in the ECU??? Please tell me i didn't
Old 03-19-2007, 05:37 PM   #2
punch
punch's Avatar
sounds like something fried to me, have you swapped out leds before?
I thought with each led you had to use a mathematical formula to determine which resitor you would need for the led, each led needs a resistor...
Old 03-19-2007, 06:23 PM   #3
Kitt
Kitt's Avatar
and it has one, that bulb is different than all the other ones, it is bigger and it says 3W on it, i assume it is 3 watts. Do you think that it goes to the ECU or to the fuel tank??
Old 03-22-2007, 01:44 PM   #4
Kitt
Kitt's Avatar
Just to let you all know, I fixed it by reseating the power by moving the key to on - lock - on and disconnecting the battery, let it there for 20 minutes, re connected the battery and it worked!!! i've never been so happy of seeing my fuel low light on!!!
low gas mileage? yrsdrgn General Yaris / Vitz Discussion 30 01-17-2019 03:26 AM
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
"Airbag" center console light on 07 Sedan with side airbags atebit In Car Entertainment + Electronics (audio / video / alarm) 5 11-10-2006 06:10 PM
