Old 04-25-2009, 02:07 AM   #1
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Rear left indicator light not working
Heya,
I was removing the rear TYC Clear tail lights and going back to the oem ones...
After putting the stock ones back, i found out that the rear left indicator light wasnt working....
When I switch to the left indicator lights, the console shows the light blinking really fast...
I removed the bulb and saw that the filament in the bulb wasnt broken... So, is my rear lights fuse gone off, or do I need to change the bulb????
Old 04-25-2009, 02:27 AM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Originally Posted by jinxor View Post
Heya,
Did you try putting battery power to the bulb? You can't always tell just by looking.
The fast flashing does normally indicate an open circuit. That would usually be caused by a burnt out bulb, but it could also mean a broken wire or disconnected plug in the indicator light circuit. If the bulb is OK when you apply battery power to it, start checking the wiring.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 04-25-2009, 03:07 AM   #3
jinxor
jinxor's Avatar
Ok... ill check that
Old 04-25-2009, 04:38 AM   #4
silver_echo
ekodrvr
silver_echo's Avatar
check the ground wire...
i like this smiley...
silver_echo is offline   Reply With Quote
When will the Yaris hit the showrooms at dealers? Petrolhead New YARIS Purchase Forum 181 11-28-2011 08:03 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
