Maintence Items Not In The Owners Manual
Spray each wheel with lube where indicated in the photo maybe once a year to prevent it from seizing to the hub. Maybe more often in Canada!
A permanent solution is to just apply anti seize or grease on the hub. My car is an 05 and I've never had a wheel stick to the hub, or brake rotor.
Good idea. Ive had them stick and kicking the tire while its on the supplied jack during a roadside emergency to get it off was scary! I ll use sntiseize if I ever have any of the wheels off. Im old and getting the wheels off is an adventure!
Antiseize ftw!
No one ever wants to give a Yaris the point by... ![]() |
I don't seem to have issues with mine the past 2 years.
But anti seize does the trick if it sticks. Sent from my SM-G930W8 using Tapatalk |
Maybe a Canadian thing. I do that to mine too, just to keep the rust off. Actually, I spray the whole steel wheel (my winter ones) a few times a season and they still look new after many Canadian winters.
I should've done that. Mine are rusty after eight years and I live in New Jersey!
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Every year when I switch back to my winter tires, I wire brush and add never seize.
I hate stuck wheels. Michigan winters are not fun especially with salt. |
Thread Tools | |
Display Modes | |
Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 10:02 PM |
2008 Toyota Yaris Owner's Manual | dinky123! | DIY / Maintenance / Service | 3 | 03-25-2015 11:26 AM |
Grimmspeed Manual Boost Controller For Sale | fnkngrv | Items for Sale by private party | 1 | 05-05-2014 01:25 PM |
Owners Manual Download?? | JeffRapp | DIY / Maintenance / Service | 4 | 04-14-2011 02:37 AM |
2009 Sedan Owners manual | magnum23 | DIY / Maintenance / Service | 2 | 10-20-2010 10:50 PM |
