Old 12-28-2009, 12:07 AM   #1
Remote Start DIY Wiring Guide 2006-2010 Yaris
I have been getting a lot of questions lately regarding installing remote start on a Yaris, so today I put together a wiring guide for those interested.
Yaris 2006+ Remote Start Wiring Guide.pdf
Old 12-28-2009, 02:10 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
sweet, now i can finally install the Remote start part, thanks alot man.
Check out my Build thread:
Old 12-28-2009, 09:18 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
You kick ass Scott!
Old 12-28-2009, 08:52 PM   #4
Revsson
CTScott gets my vote for Best YarisWorld Member of the Decade!
Old 12-29-2009, 04:45 AM   #5
upgradedyaris
Drives: Yaris & Supra
Awesome Scott, nice chatting and thanks for the advice thus far. I ordered mine today. :)
Duane
upgradedyaris is offline   Reply With Quote
Old 12-30-2009, 03:13 PM   #6
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
Attachment 30944
SWEET!
Thank you!
Reeves360 is offline   Reply With Quote
Old 12-30-2009, 03:27 PM   #7
Reeves360
Attachment 30944
Hey Scott,
Seeing as I have installed an OEM alarm which added factory keyless entry as well which remote starter what would you recommend that I use for a remote starter? I'd like to continue to use the Toyota remotes.
I would also prefer to use home made neutral safety switch so that I don't have to perform a sequence of steps every time I park the car. Do you have any suggestions on the switch that I use as well?
On a side note I would like to install the TRD push button start as well down the line even if that means I have to put in my car and turn the car to on. Do you for see any issues having both remote start and push button start. Seem to me that you wouldn't but some of the wiring for the remote start and push button start may tie into some of the same locations.
Thank you for all the excellent help here on Yaris World!
Old 12-30-2009, 05:05 PM   #8
Originally Posted by Reeves360 View Post
Hey Scott,
To add remote start, whereby you can still use your Toyota remotes, I would recommend the Valet 561T (which allows you to use your door lock signal as the remote start trigger.)
For the neutral safety input, I haven't installed remote start on a standard. In doing a bit of web research on the topic I've seen people create things as simple as an array of springs surrounding the shift lever (so that a ground connection is made if the shift lever is moved out of the neutral position).
The push start shouldn't have an impact on the remote starter. They would indeed share some connection points.
Old 02-08-2010, 03:24 PM   #9
jroy
Drives: 2007 Yaris
Anyone ever try installing a Avital 4113 starter in a Yaris? This was the only one button starter I could find locally and I need it by Wednesday (girlfriend's birthday).
jroy is offline   Reply With Quote
Old 02-08-2010, 03:39 PM   #10
It's a DEI product, so it should be decent. I just read through the install guide for it and It should be very straight forward with my DIY.
Old 02-13-2010, 08:57 PM   #11
jroy
Drives: 2007 Yaris
Hi Scott, this starter has a couple of connections I couldn't match up using your install guide.
FACTORY ALARM DISARM
FACTORY REARM
(+) IGNITION OUT (TO ALARM)
(-) ACTIVATION INPUT
And where is the neutral safety switch connection? Or is that not needed because the motor wont start unless its in park or neutral? Thanks!
-Josh
Old 02-14-2010, 12:28 AM   #12
FACTORY REARM
-Josh
Does your car have an alarm? If not those are not used, if it does and the alarm is the factory TVIP one, I can point you to those connections. If it is an aftermarket one, then you will have to refer to the documentation for the alarm.
A neutral safety switch would be used if you are installing a remote starter on a Yaris with a manual transmission. The Yaris doesn't have one, so as per my guide, you would need to purchase or create one that will work with the Yaris's shift.
Old 02-14-2010, 12:20 PM   #13
jroy
Drives: 2007 Yaris
Hi Scott, I found a wiring diagram that said:
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
So I have that covered. The other two I'm still not sure about though.
Old 02-14-2010, 12:32 PM   #14
jroy
Drives: 2007 Yaris
For the (+) IGNITION OUT (TO ALARM) it says:
As an add-on car starter: If connected, disconnect the ignition/accessory
input of the remote controlled security or keyless entry system.
Connect the H1/3 YELLOW ignition output to the ignition/accessory
input of the remote controlled security or keyless entry system. The wire
will prevent the host system from sensing that the ignition is on during
remote start operation.
Should I use the "Disarm No Unlock use key sense wire" ? That requires a negative input not a positive input like this one outputs. Should I get a relay and wire it that way?
Also, the (-) ACTIVATION INPUT,
This input comes from the factory set to 1 activation pulse. This means
that it is necessary to have 1 ground pulse on the white/blue wire for
the remote start to activate or to deactivate. The same holds true for the
remote control activation when set to a two pulse setting it is necessary
to press the button twice for the remote start to activate or deactivate.
I can't quite figure out what that means. Would this input be used if you wanted to use the factory lock button? It has a little diagram about a Momentary switch so I really don't know what its talking about.
Old 02-14-2010, 02:25 PM   #15
Whether the (+)Ignition out is required or not for yours will depend on the particular alarm that you are using. You didn't answer above, as to if it is the factory installed OEM one, or an aftermarket one.
The (-)Activation input is for triggering the remote starter from an existing remote.
Old 02-14-2010, 03:59 PM   #16
jroy
Drives: 2007 Yaris
Hi Scott, it is the factory alarm.
Old 02-14-2010, 04:30 PM   #17
OK. The TVIP OEM Alarm has a 36 pin connector:
Pin 12 (white/light blue wire) goes to a starter cut relay, so you will need to follow that wire to the starter cut relay, and tap the Black Wire coming off of that relay with your start wire. On a non-alarm car that would be the black wires on the ignition switch connector.
Pin 9 (orange wire) is the ignition switch power input to the TVIP, so if it actually needs the (+) IGNITION OUT (TO ALARM) connection, that's where it would be done.
The key sense wire is the yellow wire on the two pin connector that is near the face of the keyswitch.
Old 02-14-2010, 04:34 PM   #18
Here's connector D19, which is the key sense connection (2 pin with yellow and white/black wires):
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
