Loose air-blocking panel at right side of radiator--rattle, squeak, buzz?
(Loose air-blocking panel at right side of radiator--rattle, squeak, buzz?)
Moves freely vertically an eighth or quarter of an inch. Larger than the panel on the left side of radiator, which seems tight. Will put a piece of foam under it to take up play, pending suggestions. Curious if this involves broken or missing clips or trim, etc. (Mine had a right headlight replacement, so maybe something got altered.) Definitely something to check on any Yaris as a potential noisemaker. |
That is a large plastic piece, which should not have been touched when the headlight was replaced, but you never know. It just snaps into place.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 09:14 PM |
| DIY rear Interior panel removal 09 3dr LB | bkndacn | Cosmetic Modifications (Exterior/Interior) | 10 | 03-11-2013 02:05 AM |
| driver side A/C vent blowing hot air | Yaross | DIY / Maintenance / Service | 4 | 12-05-2011 08:51 AM |
| Chrome audio cluster side panel | ArrowWind | Cosmetic Modifications (Exterior/Interior) | 6 | 07-22-2011 02:15 PM |
| Side impact air bags... do I have them? | chumpster | Cosmetic Modifications (Exterior/Interior) | 6 | 04-27-2009 08:04 AM |
