![]() Drives: 2007 Yaris Join Date: Apr 2011
Cruise control problems
I installed the CC as per the instructions from CTScott a couple of years ago on my wife's 2007 Yaris (with indicator light). On Friday, took the car into the shop for regular maintenance and they also did the airbag recall. On the way back home, after picking up the car, my wife found the Cruise Control not working. I took it for a drive. The indicator light will come on when the key is turned to on (car not started), then didn't turn off when the car was started. Pressed the on-off button - nothing. The light will go on and off when you press and hold the lever to 'set' though.
Took the airbag off and checked all the connections under the dash, and under the steering wheel airbag, all looks good. Just wondering if anyone else has had similar issues. (Yes, I did a search) Thanks in advance. |
87 looks but nobody has an idea.
Well, no worries, i found the problem and will share it. It seems, that when I had the dealer change the fresh air filter, they must have snagged the wire going through the dash and it came apart at the butt connection I had there. Re-attached and cruise control works again. |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
Glad you got it figured out.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| Rostra 250-1731 cruise control kit for Yaris | PeetYaris | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-26-2011 07:48 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 04:55 PM |
