Old 01-30-2010, 04:50 PM   #1
DIY Cruise Control FAQ (2006-2010 Yaris)
There are many threads regarding DIY cruise control. The purpose of this one is to centralize all of the information.
By DIY Cruise Control, I am referring to using the functionality built into the US and Canadian Yaris' ECM, as opposed to installing a 3rd party cruise control system. All US and Canadian Yaris (2006+) have this capability built into the ECM. Thus far we have found that European and Australian Yaris do not.
The following chart details the scope based on year, transmission type, and DIY method. For methods, one may choose to purchase the Toyota OEM Cruise Control stalk (which mounts to the right side of the steering wheel) or to do the DIY switch method (which uses low cost push button switches and resistors to achieve the same functionality as the OEM stalk).
Part Numbers:
Toyota OEM Cruise Control Stalk: 84632-34011
Toyota OEM Cruise Control Stalk Wire (Required to connect the stalk to the spiral cable, within the steering wheel): 84633-42030 or 84633-02020 (this new PN has replaced the other)
Lower Steering wheel cover (with the hole already in it for the cruise stalk):45184-52130-B0
ECM repair terminal (Used to add the connection to pin 40 of connector A21 of the ECM on Yaris where "wiring to the ECM" is required - Quantity 1 required): 82998-24250
Spiral Connector Repair Terminals (Used to add the two pins to the steering column end of the spiral cable on Yaris where "Extra pins to the spiral cable" is required - Quantity 2 required): 82998-12870
Cruise Control Clutch Switch (Required for all Manual Transmission Yaris): 88280-14030
Here is my complete installation guide for installing cruise control on any 2006-2011 US/Canada/PR Yaris with the OEM Cruise Control Stalk:
http://tinyurl.com/CruiseDIY
Threads with specific information / DIYs:
1. The original thread where we discussed if this could be done and made the discovery that it could:
http://www.yarisworld.com/forums/sho...e+module+%2425
2. My DIY for the 2 or 4 switch method. This thread details what is required to assemble the DIY switches and connection of them to the spiral cable connector on 2009+ Yaris, which have the wiring in place from the ECM to the steering column.
http://www.yarisworld.com/forums/sho...ght=diy+cruise
3. Vince87's DIY for 07-08 (really 06-08) detailing the ECM pin connection and clutch switch installation using the 2 or 4 switch method:
4. PeteZNY's DIY for installing the OEM stalk. This thread details pulling the airbag to install the OEM stalk on an 09:
http://www.yarisworld.com/forums/sho...cruise+control
5. A link to a post detailing my Cruise Control Indicator Module, which provides a visual indicator that cruise control is on for Yaris which don't have an indicator on the cluster:
http://www.yarisworld.com/forums/sho...5&postcount=67
6. A DIY that I put together that shows how to disconnect the ECM connector an how to install the pin in position 40 of connector A21:
http://www.yarisworld.com/forums/showthread.php?t=26444
7. I have some stalks with the wire and mounting screws for sale (I also have a couple of the cruise control clutch switches, required for MT cars):
http://www.yarisworld.com/forums/showthread.php?t=32442
8. I also have some of the repair pins for the ECM connector and the steering column connector:
http://www.yarisworld.com/forums/showthread.php?t=31763
The combination of the material in the above threads covers everything required from the chart above. You may have to use parts from more than one to cover your particular installation.
FAQs not covered above:
Where can I get the OEM stalk? From a Toyota dealer, eBay or junkyards. The stalk for the Yaris is also used on the following Vehicles:
Camry 04-09
ES300 04-09
Scion TC 04-09
Sequoia 04-09
4Runner 04-09
Corolla 08-09
ES350 06-09
FJ 06, 08
GS450H 06-09
GX470 04-09
Highlander 04-09
IS F 07-09
IS250 05-09
Land Cruiser 04-09
LX470 04-09
LX570 07-09
Prius 04-09
RAV4 04-09
RX330 04-09
RX400H 05-09
Scion xB 07-09
Scion xD 07-09
Tundra 04-09
The stalk wire is also used on the following vehicles:
Corolla 08-09
RAV4 05-08
Old 01-30-2010, 06:40 PM   #2
goku87
goku87's Avatar
Drives: Black HB
Clutch Switch for MT
So far this is the cheapest place I could find it:
http://www.google.com/products?q=airtex%201s5850
$14.62 + S&H
Various shipping rates at the time of writing (basically $7.49 for CONUS):
AK - Anchorage (99501) . . . . $9.84
CO - Denver (80002) . . . . . . .$7.49
CA - Los Angeles (90001) . . . $7.49
FL - Tampa (33601) . . . . . . . .$7.49
MO - Kansas City (64101) . . . $6.13
NY - New York (10001) . . . . . .$7.49
WA - Spokane (99201) . . . . . .$7.49
Old 01-30-2010, 08:04 PM   #3
127.0.0.1
Super Nifty DIY 4 position switch for the resistor method
http://www.alliedelec.com/search/pro...px?SKU=9485541
where I installed mine
http://www.yarisworld.com/forums/sho...&postcount=187
Old 04-08-2010, 12:09 PM   #4
swidd
Drives: Yaris HB
The clutch switch for Manual Transmission sells for $22.70 + tax at my local Toyota Dealer Parts Department. That should come out to the same, or less than, the above quoted $17 + shipping.
Also, Radio Shack, Lowe's, Home Depot and SEARS do NOT carry any four-way switches.
Old 04-09-2010, 03:21 PM   #5
fcharlan
Hi everybody, I have a Canadian 2007 Yaris and was wondering if someone from Canada tried the DIY Cruise control on their vehicle? I read that the ECM might not be compatible.
Thanks
Dan
fcharlan is offline   Reply With Quote
Old 04-09-2010, 03:37 PM   #6
Thanks
Dan
Canadian ECM's are fine. I am aware of a least a couple of people from Canada who have added DIY CC.
Old 04-09-2010, 05:19 PM   #7
fcharlan
Thanks a lot for the info. I will try it.
Old 04-14-2010, 07:32 PM   #8
carlosgil5
Drives: 2010 AT 5dr Liftback
Guys I really want to do this, I just bought a 2010 AT Mexican Yaris from the local dealer, but I don´t know if there´s any difference between mexican, american or canadian yaris. Am really close to the Arizona Border so I can easily buy the required parts but am afraid my ECM is not compatible, any ideas?
carlosgil5 is offline   Reply With Quote
Old 04-14-2010, 10:25 PM   #9
Mexican Yaris get a different ECM than US and Canadian ones, so you would definitely have to test it to see. The place to start is to measure the voltage on the ECM pin 40, with the ignition in the on position. If you see 12 Volts on that pin, then there's a good chance that it will work.
If you shine a flashlight around on your instrument cluster, do you see the two icons for cruise control?
Old 04-15-2010, 11:26 AM   #10
carlosgil5
Ok, thanks for the info CTScott, am gonna check voltage and instrument cluster before start buying stuff ...So many things to do with this yaris.
Old 05-17-2010, 11:35 PM   #11
Originally Posted by cpchri1 View Post
Hi CTScott -
I have an auto 2010 Yaris 5 door hatch (U.S.) with the power package, I have the CC lamps on my speedometer counsel (unlit at this time), and want to put in the DIY CC. In your post you reference the following part numbers:
However you also reference PeteZNY post (2009 Yaris 3 door hatch with power package) and he references the following part numbers:
84632-08021 Cruise control switch
84633-02020 Cruise switch wire
90159-50199 Screws (2)
But I'm confused??? What parts should I order?
Thanks!
CPCHRI1 Eastern WA State
2010 Yaris - Added OEM RS3200 Security System, OEM Ipod connector, OEM Bluetooth
2009 Matrix - Added OEM RS3200 Security System, OEM Ipod connector, OEM Bluetooth
2009 Camry - Don't own techstream so had dealer tech add Security System, OEM Bluetooth (note: Toy tech messed it up RS3200 security install)
1985 Toyota PU 22R (w/ LC Engineering timing case conversion kit and hardened OH Cam)
The EPC shows the 84633-02020 cable as being for the Corolla or Matrix, whereas 84633-42030 is for the Yaris and RAV4.
It shows the 84632-08021 stalk as being for a bunch of cars, not including the Yaris, where as 84632-34011 is shown for a bunch including the Yaris.
Apparently, in these two cases the parts not listed for the Yaris do work with the Yaris as well.
The screws are needed. The lower steering column cover is optional. You can either drill a hole for the stalk, or buy the lower cover with the hole already in it.
Old 05-18-2010, 05:49 PM   #12
dingbat
Drives: '10 3D Liftback
Just did this mod today on my '10, 3door, base trim.
Soooo very easy and way cheaper than what the dealer wanted for an aftermarket setup at time of sale!
Thanks to everyone who put all the info together!
dingbat is offline   Reply With Quote
Old 05-19-2010, 07:06 PM   #13
sk8manmike
sk8manmike's Avatar
Drives: 2007 Yaris 4d Sedan
I think I'm going to make a video DIY for this mod since it seems to be so popular. I just wanted to make sure that no one else has already made one - I don't want to be THAT guy
sk8manmike is offline   Reply With Quote
Old 05-24-2010, 09:38 AM   #14
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Lightbulb Instrument cluster
Is the Instrument Cluster for 09-10 model is bolt-on to 06-08 model? Goal is to have my yaris '07 model with CC indicator on Instrument panel
ricepower is offline   Reply With Quote
Old 05-24-2010, 11:20 AM   #15
The newer cluster will work on the previous years, but I don't believe that the cruise control indicators will work, as the ECM has to send the message via CAN bus to the cluster to light up the indicator. From experimentation that I have done, I have noticed that an 07 ECM doesn't send the asynchronous message to the cluster when cruise control is activated.
Old 05-24-2010, 11:34 AM   #16
Also, I am about 90% sure that your car will not have the cruise control functionality built into its ECM, since it seems to be just USDM cars that have it.
Old 05-24-2010, 03:31 PM   #17
ricepower
ricepower's Avatar
Lightbulb
With your experience, will you please add your earlier post the P/N's of ECM with CC functionality
Old 05-24-2010, 04:26 PM   #18
89661-52F10
89661-52F11
89661-52F11
89661-52G30
89661-52G50
89661-52G50
89661-52G51
89661-52F01
89661-52G40
89661-52G40
89661-52G30
89661-52G41
89661-52E90
89661-52E91
89661-52J50
89661-52J40
89661-52J30
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
