Old 05-18-2010, 12:13 AM   #10
cpchri1
Drives: Red Yaris
CONFUSED ON YARIS CC PART NUMBERS
Hi CTScott -
I have an auto 2010 Yaris 5 door hatch (U.S.) with the power package, I have the CC lamps on my speedometer counsel (unlit at this time), and want to put in the DIY CC. In your post you reference the following part numbers:
Toyota OEM Cruise Control Stalk: 84632-34011
Toyota OEM Cruise Control Stalk Wire (Required to connect the stalk to the spiral cable, within the steering wheel): 84633-42030
Lower Steering wheel cover (with the hole already in it for the cruise stalk):45184-52130-B0
However you also reference PeteZNY post (2009 Yaris 3 door hatch with power package) and he references the following part numbers:
84632-08021 Cruise control switch
84633-02020 Cruise switch wire
90159-50199 Screws (2)
But I'm confused??? What parts should I order?
Thanks!
CPCHRI1 Eastern WA State
2010 Yaris - Added OEM RS3200 Security System, OEM Ipod connector, OEM Bluetooth
2009 Matrix - Added OEM RS3200 Security System, OEM Ipod connector, OEM Bluetooth
2009 Camry - Don't own techstream so had dealer tech add Security System, OEM Bluetooth (note: Toy tech messed it up RS3200 security install)
1985 Toyota PU 22R (w/ LC Engineering timing case conversion kit and hardened OH Cam)
cpchri1 is offline   Reply With Quote
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
