Old 09-29-2010, 10:57 AM   #1
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
What size are 1ZZ-fe injectors?
I have injectors from a 98-99 corolla and I need to now what size they are in cc. Thanks
pimp my yaris is offline   Reply With Quote
Old 09-29-2010, 12:04 PM   #2
xbgod
Drives: "Burning It Down GTX2860RS XB"
They're around 200cc, but hey I told you I would get you those injectors as soon as I get in. So don't go wasting your money. Those Precision Injectors I have are 380cc and cost around 450.00. You will not find a better injector than Precision. they are flow matched, meaning you will get exact amounts of fuel per cylinder.
Merry X-mass
XBG
xbgod is offline   Reply With Quote
Old 09-29-2010, 12:04 PM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
240-260cc.
I'm thinking they're most likely 260cc though.
Old 09-29-2010, 12:43 PM   #4
cdydjded
Drives: Yaris LB Turbo
Take them to a place that can flow them. Guessing is not the way to go. I can assure you that the 1ZZ injectors I have flow 220cc. But they came from a Toyota Celica not a Corolla.
xB: 380cc's are too big for our use. I have the 1ZZ's & they run very rich.
Old 09-29-2010, 12:47 PM   #5
pimp my yaris
C'est la vie
Merry X-mass
XBG
I already had these injectors. And I was under the impression that 1NZ injectors were 190-200cc. The problem is I am allready runing lean in the 5-6K range. So I wanted to install these until I recieve your larger injectors. Believe me I appriciate it very much.
1zz must be larger then 200cc though. I just want to program my FIC correctly.
Old 09-29-2010, 12:49 PM   #6
xbgod
Understandable dude, didn't want you to spend undue money.
Rock-on
XBG
Old 09-29-2010, 12:50 PM   #7
pimp my yaris
C'est la vie
Three guys three answers
Old 09-29-2010, 12:51 PM   #8
xbgod
And you don't have to run the full duty cycle of the 380cc injectors, thats what your fuel management is for.
I would hope with the AEM/FIC you could control a 380cc injector.
XBG
Old 09-29-2010, 12:53 PM   #9
pimp my yaris
C'est la vie
XBG
Yes you can program up to 1000cc
Old 09-29-2010, 12:55 PM   #10
xbgod
Pimp,.....I'll make a personal call to Greg Nakono over at AEM for you. I'm pretty sure you can control those 380cc injectors. Then you'll also have room to grow.
I'm 680cc yeah...I have full-standalone but controlling a injector shouldn't be an issue.
XBG
Old 09-29-2010, 12:57 PM   #11
pimp my yaris
C'est la vie
I guess I will try changing to 220cc and see where my AFR is
Old 09-29-2010, 12:58 PM   #12
xbgod
Thats what I thought.
Never tell me something is too big...I'll make fit and work anyways
XBG
Old 09-29-2010, 12:59 PM   #13
pimp my yaris
C'est la vie
I know the FIC can handle it and I know how to calculate for larger injectors. I was just looking for flow rate on 1ZZ 98-99 corolla injectors
Old 09-29-2010, 01:00 PM   #14
pimp my yaris
C'est la vie
The FIC is awsome I am learning so much by making my own map.
Old 09-29-2010, 01:40 PM   #15
pimp my yaris
C'est la vie
This is the part number if that helps?
Old 09-29-2010, 01:43 PM   #16
pimp my yaris
C'est la vie
Someone should make a injector flow chart with toyota part numbers. Mabe a bench flow testing master like cdydjded.
Old 09-29-2010, 02:04 PM   #17
kou
Drives: 08 lb
http://injectorrx.com/densotf.html here you go.
http://www.fuelinjector.citymaker.co...INJECTORS.html
Old 09-29-2010, 02:32 PM   #18
pimp my yaris
C'est la vie
Thanks so much for the link. Unfortunatly my part number is not listed. The closest one 23250-22040 says 255cc. Any way I put them on my car and it still goes lean. These injectors seem about the same as stock. I recalibrated my FIC map from 200cc to 220cc and my AFR got leaner across the entire rpm range. So not big enough. For now I returned back to 200cc calibration, until I get bigger squirters. O well it was worth a shot. Everyone should save those links.
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 11:11 AM
FS: 05 1zz t/b and injectors OTA'sTOY Items for Sale by private party 4 06-03-2010 09:07 PM
1ZZ Injectors on NA Setup MGargano Performance Modifications 14 04-22-2010 02:02 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 05:15 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
