Old 07-26-2007, 11:56 AM   #1
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
Exhaust Pipe Size (Tamaņo del tubo de escape)
Bueno este tema lo saque de www.scionlife.com me parece bueno que se sepa a la hora de hacerle la tuberia a nuestros autos que tamaņo tomar de referencia.
Posted: 8/6/04 9:13AM Post subject: Exhaust Pipe Size.
This is just some ramble I thought of & had nothing better to figure out, this information is all done by me, so I know some of it might be wrong I am no math major. Use this information in any way you want, just dont blaim me for any problems you have with it.
American Standards:
Stock Pipe:
Pipe Size = 1.75"
Pipe Surface Area = 2.4"
Pipe 2:
Pipe Size = 2"
Pipe Surface Area = 3.14"
Pipe 3:
Pipe 3 Size = 2.25"
Pipe 3 Surface Area = 3.97"
Stock Pipe vs Pipe 2:
Increase in Diameter = .25"
% of Increase = 14.28%
Increase in SA = .74"
% of Increase = 30.83%
Stock Pipe vs Pipe 3:
Increase in Diamete = .5"
% of Increase = 28.57%
Increase in SA = 1.57"
% of Increase = 65.5%
Metric Standards*:
Stock Pipe:
Pipe Size = 45mm
Pipe Surface Area = 1590mm
Pipe 2:
Pipe Size = 50mm
Pipe Surface Area = 1963mm
Pipe 3:
Pipe Size = 55mm
Pipe Surface Area = 2375mm
Increase in Diameter = 5mm
% of Increase = 11.1%
Increase in SA = 373mm
% of Increase = 23.5%
Increase in Diameter = 10mm
% of Increase = 22.2%
Increase in SA = 785mm
% of Increase = 49.4%
* All the metric numbers are rounded for more simple math. Also The pipe 2 & pipe 3 size are different then the american standards, I did this to show if using mm to measure your exhaust & have pipes made in that size, its much easier to figure out.
Im sorry if information like this has been posted before. The infomation could be used for basics in helping you decide what size exhaust you want. It also shows how that just by increasing from 1.75" pipe to 2.25" pipe is a big difference, might make some people think about a full cat back in the 2" pipe size. This information is also just the pipe, when figureing exhaust flow one needs to know a lot more then just this information.
http://www.scionlife.com/forums/viewtopic.php?t=22925
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
Old 07-26-2007, 12:36 PM   #2
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
Buena informacion pero tengo una pregunta:
todas estas medidas se hicieron en el motor 1nz?
pregunto porque ese es el motor que traen los scion XA y XB
solo para aclarar, muchas gracias
It's a Vitz!
Vic-2NZFE is offline   Reply With Quote
Old 07-26-2007, 02:32 PM   #3
titoteng
1NZ power
titoteng's Avatar
Drives: Yaris T-sport 2002
IZ BARNIZ!!!!! 1NZ
titoteng 纳尔逊登
2002 Yaris T-Sport@Thunder gray
Arospeed CAI, 4300K HID
Pioneer ice/speakers, MTX SUB/Amps
titoteng is offline   Reply With Quote
Old 07-26-2007, 02:32 PM   #4
carlosh
carlosh's Avatar
Eso es correcto. el 1NZ se le puede meter maximo 2.25 en tuberia.
Old 07-26-2007, 02:44 PM   #5
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
entonces hasta cuanto puede llegar la tuberia para el motor 2nz
como el mio? por otros foros he escuchado que hasta 2" es lo maximo
para le 1.3L
It's a Vitz!
Old 07-26-2007, 03:13 PM   #6
carlosh
carlosh's Avatar
para le 1.3L
Me parerece que 2" esta bien pero puedes tomar como referencia el diametro actual de tu tuberia y sumarle 1/4 = 0.25 Inches...
Old 07-26-2007, 03:47 PM   #7
carlosh
carlosh's Avatar
Este site tiene una informacion muy buena sobre el litraje de los motores y el tamaño del exhaust. http://www.longbeachmuffler.com/faq.html#WHAT
Old 07-26-2007, 09:45 PM   #8
Fer.pa
Fer.pa's Avatar
Drives: Yaris HB
Send a message via MSN to Fer.pa
2 pulgadas por lo menos sin problemas en el 1.5 nose si en el 1.3 cuando le meta mente a eso le pondre mi experiancia.
Super Yaris Panamá
05 HB - 2NZFE 1.3L Engine - 068 Super White - Aem CAI - Trd Oil Cap - Rev 17" rims -Toyo 205/40/17 wheels - Vibrant Front Strut Bar - Tein-S springs - KYB Gas Shocks - Header DC-S 4-1- Tenzo-r steering wheel- Pioneer Avh-P 5750
Fer.pa is offline   Reply With Quote
Old 08-02-2007, 02:31 PM   #9
carlosh
carlosh's Avatar
Catalizador de alto rendimiento
Hablando de cambiar la tuberia a 2" es necesario cambiar el catalizador por uno que deje pasar mas flujo de aire.
Este me parecion bueno, ademas de ser una compaņia lider en el mercado de catalizadores (magnaflow).
http://www.car-sound.com/02product/d...niversal=53163
Old 08-02-2007, 03:22 PM   #10
Vic-2NZFE
Vic-2NZFE's Avatar
Drives: Yaris 2NZFE
que pasa si le dejas la tuberia a raja tabla (straight) no es mejor?
It's a Vitz!
Old 08-02-2007, 03:47 PM   #11
Fer.pa
Fer.pa's Avatar
Drives: Yaris HB
Super Yaris Panamá
Old 08-02-2007, 04:15 PM   #12
carlosh
carlosh's Avatar
Si se puede, pero no se cuando en panama empiecen a regular que todos los carros tengan cata.. como en el norte lo hacen (tu sabes cuestiones ecologicas)
ademas tuberia directa te daria mucho ruido, "Aunque" es posible meterle varios muflers a lo largo del la tuberia (como tiene los Mitsubishi lancer)
