Old 09-25-2017, 02:34 AM   #1
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
Air filter.
Just managed to get a hold of the K&N air filter for my 1.3. This filter was elusive for a while until I stumbled across one at a local store here in South Africa. Ironically it was the last one they had as they said it was not a major seller as most yaris owners here get the paper filters.
It has made a noticeable difference in acceleration and smoothness, plus I've dropped half a litre in fuel consumption. Tight squeeze to get it in but it really is worth it. Would recommend giving it a try.
Model 33-2211
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 09-25-2017, 07:46 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
The perceived improvements are probably a pacebo effect.
If these aftermarket, "go faster" addons were of any use don't you think Toyota or any other manufacturer would fit them at the assembly plant?
mrpj is offline   Reply With Quote
Old 09-25-2017, 07:51 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Actually not. They were built by design, and with tons regulations by the governments.
Now, any increase in air flow (intake, header, exhaust) will bring the power band upon, so you will feel the car being more "alive" when you rev it.
Though, I doubt it decreases fuel consumption to a noticeable level.
Old 09-25-2017, 12:54 PM   #4
gedster314
Drives: Asolute Red 15 Yaris
Been through the air cleaner and oil wars in the TDI Club in the early 2ks. Many participents were engineers with access to cool test equipment and electron microscopes. There was no appreciable performance gain, especially when compared to the increased amount of dirt these oiled gauze filters allowed in. The dirt may not be such a big issue with a normally aspirated engine but it is a problem with a turbo blade turning at 100k rpms. At 100,000 miles blades are rather beat up.
Many of these engineers commented that even new filters were bad for your car and that to a point, dirty filters were more effient at keeping dirt out. They ran air restriction meters to determine filter changes and not mileage or visual instpection. Some TDI owners were truely anal about vehicle maintenance.
Drive 30K with your KN filter, pull your intake hose and look at the inside and then look down your intake manifold throat. If your happy with what you see then keep using the gauze filter.
gedster314 is offline   Reply With Quote
Old 09-25-2017, 01:43 PM   #5
bronsin
bronsin's Avatar
Originally Posted by RicStyx View Post
Ironically it was the last one they had as they said it was not a major seller as most yaris owners here get the paper.alk
That's because the Toyota filter is 99% efficient at removing dirt whereas the oiled Element filters are 95% efficient.
Also the oil on the filter has a way of getting on the wires of the MAF sensor and causing problems.
Old 09-25-2017, 06:50 PM   #6
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
All I can say is what I've said about my K&N in the past. I got it not really expecting performance gains, but just thinking it would be a money saver. I also didn't feel any performance improvement after installing it; however, after disconnecting my battery for a different reason, I noticed the car feeling less bogged down after the fact and couldn't figure out why. Someone speculated that disconnecting the battery reset the ECU and caused it to relearn to take advantage of the additional air-flow from the K&N, which resulted in me noticing an improvement. I don't know how much of that explanation is plausible and how much of it is pure placebo. All I do know is that if I go swap my K&N for the paper filter I had in prior, start the car up and step on it as I'm heading up my street, it feels less bogged down with the K&N than the paper.
These days I'm thinking about throwing the paper back in because it's about time to clean the K&N and I just don't feel like dealing with it. The savings from not having to buy new filters all the time is somewhat offset by the nuisance of having to clean, dry, oil and dry the damn thing.
Call me crazy.
On Instagram
On Wheelwell
Old 09-26-2017, 10:15 PM   #7
RicStyx
I guess at the end of the day it is in my car and I've had them in my previous cars aswell. And I believe and see the benefits of the filters. All my cars have seen benefits from them so I'm comfortable paying the price. My MAF sensor has never been oily before or after using these filters, i have a basic microscope and under magnification I can't see anything and the voltage levels are at factory settings on and out of the car.
Cleaning it i do when servicing the car so it really isn't a bother at all.
I must not however that when I had the paper filter in I cleaned the throttle body out and MAF sensor, the body had a small amount of dirt already there and the sensor had some type of dust on it, so in my mind the paper filter is quilty of not filtering all that good.
But again, I know some approve and some don't, but I trust having it in my cars and do see the benefits of them in fuel and acceleration not necessarily a power increase though.
Fuel filter replacement jaimico DIY / Maintenance / Service 43 03-07-2023 12:05 PM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 10:28 PM
Clean your air filter for better mileage daf62757 General Yaris / Vitz Discussion 12 01-24-2012 01:56 PM
Which Engine Air Filter to choose? YANGSTER Performance Modifications 16 09-29-2007 11:48 AM
