Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
delete front sway bar?
Ive always had an issue with lighting up the inside wheel with any sort of turning load...I currently have the UR 23mm front, and 19mm rear
I aint got the money for an LSD, but Ive heard of other FWD racers doing this with good results. I actually did the same for my Tercel recently & just like the way the car feels overall...but with it still an auto, I dont have traction issues as I have about 20HP getting to the wheels ![]() I'm considering removing the rear bar too as the car is very tailhappy (actually I find it very amusing) I can use the sliding to my advantage as I have today to drop nearly a full second off my run time
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
delete front sway bar? Toyota Yaris Corolla Tercel
89 Tercel had no front sway bar and similar integral-sway-bar rear as Yaris. 91 Generation 6 Corolla wagon, last subcompact Corolla, has same weight and power as Yaris, lower and longer than Yaris, and no anti-sway whatsoever.
Both those old Toyotas are great on gravel. I'd really like to try sway bar delete on Yaris...also removes weight and stored parts won't get rusty. Bar seems hard to get to (some have disconnected links to see traction effect.) Is Yaris sway bar hollow? If not, it looks heavy. Anyone know weight? |
#3 | |
#4 | |
Obsessed with 1.5L
Tokico Blues on TigerTec springs. Stiffest spring on the market when I bought em 6 years ago. It probably aint enough anyway, especially if I decide to run the 225 hoosiers again. I should probably just get my tercel done sooner instead of messing with the Yaris. I have Fortune Auto coilovers on that and it actually rides nicer sadly
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 06:25 AM |
| FS Cusco coilovers, ultra rear sway, gt spec bracing, miracle x cross bar seibon hood | blacksandiegovitz | Items for Sale by private party | 23 | 10-24-2015 12:47 PM |
| Tanabe Front Strut Bar | Benggolf2 | Performance Modifications | 57 | 08-15-2014 03:41 AM |
| front sway bar install | birdman | DIY / Maintenance / Service | 5 | 10-04-2009 09:41 AM |
| Rally Sway Bar setups | Bill@WORKS | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 09-23-2009 10:01 PM |
