Old 02-19-2007, 07:14 PM   #1
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Quickie pics of the Tanabe springs install
NEW PICS ON PAGE 2!
I'll have better pics later in the week when the sun is out, it was getting late today.
The install went ok, but I decided to remove all the wiper assembly to make removing the strut top nuts easier. It would be a much easier install if the Yaris was like normal cars with the front strut tops being easily assessible under the hood without removing a bunch of shit.
Air tools would make those 19mm bitch nuts easier to remove too, but my bruised hands got me through it.
The car is a LOT lower, these are the Tanabe DF's and pics don't do justice as to how low the car is.
Nimble is offline   Reply With Quote
Old 02-19-2007, 07:17 PM   #2
Nimble
Only other "mods" so far is a rear debadge and a hubbie removal. Up next since it's getting warmer here is a sand and black spraying of the front/rear "T" badges. Then a 20% set of rear 3 tint films. Maybe a TRD rear sway bar someday too.
As you can see from the driver's side angle pic, the offset of the stock turd narrow 5" wheels looks lame. I need some nice 15 x 7's or 16 x 7's and some fatty 205's.
Old 02-19-2007, 11:56 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
"fatty 205's"? a 225/50 will fit nicely on a 15X7m I only think there are 2 of us running this size, but it is a hugh improvement and no rubbing problems
Old 02-19-2007, 11:59 PM   #4
Nimble
With the Tanabe springs I have, no way will 225's fit without a perfect offset, and even then, with any added weight, my car would rub. The car is pretty slammed with these springs. Besides, no 100hp fwd car needs 225's, I like my gas mileage. 205's, or maybe even 195's for me. The tire compound is more important to me.
Tanabe DF, Debadged, stripped, Black emblems
Old 02-20-2007, 12:12 AM   #5
Black Yaris
der Zeck
no rubbing when it is lowered, here is proof http://www.yarisworld.com/forums/fun...?do=view&id=44
The advantages of running the 225's a re cornering, shorter braking distance, grab and go on hard accel... no spinin tires. And for the off set +38 will do ya with no rubbing problems, even if it is lowered +3 fat friends... also my gas milage has not been effected by running 225's... exactly what compound are you looking for?
Old 02-20-2007, 12:28 AM   #6
Nimble
I want summer, max dry traction, because I have the stockers for winter. But saying that the 225's reduce wheelspin on a Yaris is comical, sorry man. In order to spin the tires, you need to be dropping the clutch like a idiot. Trust me, the brakes will fade FAR before a good sticky 195 tire will. I think you're buying into the "bigger is better" hype too much. BTW, all things equal, a 195 15 tire will weight at least 3 lbs less than a 225 15 tire, that will affect the acceleration and gas mileage negatively.
No need to debate it with me, nothing you say will have me putting full size German car tires on my little Jap hatch.
Old 02-19-2007, 07:20 PM   #7
Nimble
And a few other pics in the garage both during and after install.
Old 02-19-2007, 08:18 PM   #8
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Welcome to the DF club.
Old 02-19-2007, 09:30 PM   #9
Nimble
Thanks bud.
Old 02-19-2007, 10:46 PM   #10
magoo_lc1
Drives: honda civic hatch
Looks good. I like the whole little pissed off roach look of the lowered black hb . Let me now in a week or 2 how the ride iw withe the stock struts. I forget is the df or nf the lower one of the 2 tanabe?
91 SE-R. R.I.P old freind
The influence of peers on individual behavior illustrates the seductive power of conformity
And, I don't mind at all being looked down upon by purists. Indeed I don't mind at all being looked down upon by those whom I do not look up to at
magoo_lc1 is offline   Reply With Quote
Old 02-19-2007, 10:48 PM   #11
magoo_lc1
BTW i might be coming up on a set of rota circut 8 in bronze about the middle of march. 15x7 no curb i think they weigh about 12/13lbs. If you interested ill give you a hook up.
Old 02-19-2007, 11:57 PM   #12
Nimble
So far so good. These are the DF's which claim to lower 1.9 front and rear, or is it 1.8? Anyways, the car actually is lowered more like 2 front/rear. I'm used to BMW's where the rear is lower than the front, and my car now is the opposite. I have the rear area stripped though, no spare, tools, etc, but I do have the seats still in (for now). So maybe the removal of 40-50lbs raised the rear a bit??
Based on the "finger test" I have about 2 full finger widths in the rear from tire to fender, and about 1.5 in the front. It's weird though, I expected to be able to push down on the car and see the springs "bounce" somewhat, but the car is surprisingly stiff (for now, as I do not see these stock shocks lasting over 25K miles).
Old 02-20-2007, 10:56 AM   #13
Chris07LB
Chris07LB's Avatar
Magoo - the DF's are lower then the NF's.
Old 02-20-2007, 05:35 PM   #14
501
Drives: 07 yaris
i have been running the falken rt615 in a 205 40 set up i also have the df210 on trd struts. with no rubbing at all. the problem i have is with the extra grip is that the spring weight isnt stiff enough so i still experience some body roll when cornering aggressivly. maybe a few chassis pieces will help a little. when you go over a speed bump at an angle the car shows quite a bit chassis flex.
some nice wheels would like good i always like the black on black. was my first color choice also. looks good
'07 blazing blue hatch-TRD shocks-tanabae df210-TRD rear sway bar-koning feathers 16x7-the basics for now
501 is offline   Reply With Quote
Old 02-20-2007, 05:59 PM   #15
Nimble
Thanks man. I haven't noticed the bad chassis flex....yet. I'm still on stock tires, and all I have to compare to is the stock springs, which swayed like a mofo. I'm sure once I get the sticky 205's, I'll notice it more.
Old 02-20-2007, 06:26 PM   #16
Nimble
New pics cleaned up today and I also stripped the rear and said adios to that stupid center seatbelt that dangled in the rearview.
Old 02-20-2007, 06:28 PM   #17
Nimble
Car is detailed with Poor Boy's products in these pics. Their Bold and Bright tire shine, Quick wax+, and spray and gloss QD'er. Even though the car is new, it still has some 'light' contamination embedded in the paint from the travel here, so it is awaiting a Natty's Blue Carnauba paste wax treatment after I clay her. Probably will be done in a week or two, weather permitting...
Old 07-24-2007, 02:46 AM   #18
wushumasterku
Drives: 06 White LE HB 5spd
are those stock 14"??
wushumasterku is offline   Reply With Quote
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
TANABE SPRINGS C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 11-20-2008 07:38 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 09:57 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
