Old 05-19-2006, 10:13 PM   #1
C2AUTOSPL
Drives: 240sx, 00 Celica
TANABE SPRINGS
TANABE USA will be coming out with 2 lower springs for your Yaris.
DF210
Front: 1.6in (SPring rate 3.0 kg/mm)
Rear: 1.8in (SPring rate 2.2 kg/mm)
NF210
Front: 1.1in (Spring rate 2.5 kg/mm)
Rear: 1.3in (Spring rage 2.5 kg/mm)
Available in June
Pics will be up shortly for both springs to give you guys an idea on what it looks like.
Just incase you guys are wondering, yes its for NA Yaris.
C2AUTOSPL is offline   Reply With Quote
Old 05-20-2006, 12:32 AM   #2
birdy
I stay G'd Up
birdy's Avatar
Drives: 02 wrx wagon
Send a message via AIM to birdy
sedan and liftback?
birdy is offline   Reply With Quote
Old 05-20-2006, 01:11 AM   #3
El Jefe
Drives: 07 yaris s sedan
it wont matter, the suspension are the same and the weight isnt enough to make a difference
El Jefe is offline   Reply With Quote
Old 05-20-2006, 01:16 AM   #4
El Jefe
more pics here http://www.tanabe-usa.com/search.asp...&action=search
Old 05-20-2006, 07:20 AM   #5
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Seems like the TN121's are the way to go if you plan on actually having people in the car instead of just being outside taking photos of it.
Idjiit is offline   Reply With Quote
Old 05-20-2006, 10:34 AM   #6
DVS YARIS
DVS YARIS's Avatar
Drives: yaris 1.5 yrx
i wonder if you can buy a set of tdf121 for the rear and tnf121 for the front ??
DVS YARIS is offline   Reply With Quote
Old 05-20-2006, 03:18 PM   #7
El Jefe
i was hopeing for tein to come out with their h-tech springs for the yaris because i've allways used tein coilovers and springs on my other cars when i could and like their quality, but looks like tanabe will get my buisness with the NF121's i don't want to loose the ride quality on this car
Old 05-20-2006, 05:02 PM   #8
ricko
ricko's Avatar
Drives: Copper-Orange Yaris RS
So what is the difference between these and the TRD (Eibach) springs???? What's the cost for a set????
ricko is offline   Reply With Quote
Old 05-20-2006, 05:25 PM   #9
El Jefe
msrp for the df121 is $200 and for the nf121 is $220 i dont know the specs on the trd springs so i couldnt help you on compairing them
Old 05-21-2006, 01:49 AM   #10
birdy
I stay G'd Up
birdy's Avatar
pretty nice drop
Old 05-22-2006, 11:16 AM   #11
Calidrifter
Drives: 1997 Nissan 240sx
you can't compare the two because Toyota also includes new shocks I believe. But regularly Eibach costs about the same ($200-250 range).
Also on past models (i.e. Celica, MR-S) they have had two types of springs, both labled as TRD, the pro kit (1.5 drop) and the sportline (2.0 drop) but you had to seach for them by part number at the dealership you guys think that they will have the same thing for the yaris?
Calidrifter is offline   Reply With Quote
Old 05-22-2006, 11:23 AM   #12
Idjiit
5 Stars, Bitches
No, you can buy the springs separately. The full shocks/springs TRD kit (that hasn't been released in the US) will likely be around $500. The springs alone are about $160.
Old 05-22-2006, 12:16 PM   #13
Calidrifter
Thats good to know. But I would rather they just switch everything out at once I have had problems wiht my Tein S.tehcs and my KYB GR2's on my 240 so I would feel more comfertable doing it all at once.
Old 05-22-2006, 02:36 PM   #14
Ron
Drives: BBM Yaris HB
the TRD/Eibach's drop the car ~1.3" from what I understand. With a new car and new shocks, such a mild drop should not blow your shocks out significantly faster. With an older car like the 240/older civics, yes there are problems going to a stiffer spring without replacing your shocks.
that is an odd spring rate in the rear for the Tanabe DF's... softer than the ones with half an inch less drop??
Ron is offline   Reply With Quote
Old 05-22-2006, 06:49 PM   #15
birdy
I stay G'd Up
birdy's Avatar
always replace shocks when you replace springs, or you will be doing it soon after. Not really saving any money. Shocks are like 300+ for all 4 from what I have seen which isn't that much.
Old 05-22-2006, 07:51 PM   #16
C2AUTOSPL
I instaleld ground controls on my celica when I just got it and lowered it 2in all around with stock shocks. Shocks never blew or any signs of wear til I replaced it with TRD shocks(after 3 years).
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL
24711 Redlands Blvd., Ste. I
Loma Linda, CA 92354
T: 909-796-8189
E-mail: info@c2auto.com
AIM: wide180sx
Old 05-22-2006, 09:11 PM   #17
birdy
I stay G'd Up
birdy's Avatar
thats all well and good but new shocks are always good for new springs, especially if they are made for a lower stance.
Old 05-23-2006, 02:58 AM   #18
Ron
not necessarily just new shocks, but the right type of shocks as well. if you are really into performance, getting shocks with firmer damping, perhaps even adjustability, will enhance the overall ride and allow you to tune the shocks to the springs for their particular use.
like i said, for normal every day use, there really isnt much problems using stock shocks with lowering springs. oem shocks should be replaced what, every 100k km's or so? using lowering springs maybe will take 20k km's off its life expectancy? our cars are still so new, the stock shocks are still in good shape and capable of keeping up with slightly stiffer springs. if our cars were getting up there in mileage, and the stock shocks are getting to the point where they need to be replaced anyways, then upgrade and replace then.
now if you were planning on driving the car aggresively via auto-x, track days, etc etc, then that's a different ball game. me, i just want to get rid of the 4x4 look, and reduce the body roll :)
TRD OR Eibach...i'm confused... hoahmaru Wheels, Tires and Suspension Forum sponsored by The Tire Rack 39 11-07-2008 08:25 PM
Factory lowering springs VitzBoy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 53 05-16-2006 05:25 PM
