![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
Radiator cap.... answer asap if possible
not sure if this is the right place to post but move it if need be. i was wondering what is the cap pressure? on them cause i wanna get a diffrent one but i dont know what the psi is
"It hurts more when its wet" |
i would answer if I knew...
-- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
wow fast responce.... lol im looking in the online manual for answer also lol
![]() ![]() Drives: Toyota Join Date: Apr 2007
If I am not mistaken, the number on your stock cap tells you the pressure.
Edit: I think it's 1.1 kg/cm^sq. The only place I have seen a TRD 1.1 cap is at trdsparks. Make sure it's type-N, not S.
ok understood. now my second question is the TRD booklet says that there Radiator cap for the yaris is 18.5 thats a big jump from the stock 1.1 no?
YarVitz
Drives: 07' Yaris Liftback Join Date: Sep 2006
the good news is, i am a math major, so gimme a min...
18.5-1.1=....carry the 5....divide the cosigns...yeah yeah its 17.4 better. I'd say go for it. |
i ment in effect to the engine... well cooling system. can it do more harm then good?
If you are in NJ, I wouldn't bump the cap pressure. Afterall, you didn't mod your engine to run super rich, and the winter might cause over-cooling during start-ups.
![]() Drives: Black YARIS RS Join Date: Apr 2007
the pressure on the cap is rated in bars
Just to clarify some convertion.
Bar = kg/sq.cm psi = lb/sq.in 1.1 kg/sq.cm = 15.9 psi 1.3 kg/sq.cm = 18.85 psi
ahhhh ok thanks
when the engine gets hot, coolant builds up pressure. the cap just relieves some of the pressure and puts it in the overflow tank. when it cools down it goes back into the radiator. If u decide to let the engine build up some more pressure than recommended, i think your gonna see some leaks somewhere (ie. water pump)
icic ok thanks
| Need 07 Sedan Tail Light wiring info ASAP | atebit | General Yaris / Vitz Discussion | 3 | 09-07-2013 06:48 PM |
| NEED HELP ASAP JDM Tails Install PLZ | MrMondayNite | DIY / Maintenance / Service | 6 | 04-14-2007 06:54 PM |
| Need some advice! i want my yaris asap :) | yup101 | General Yaris / Vitz Discussion | 3 | 01-15-2007 08:43 PM |
| need a fast answer from you pro's | silverRS | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-14-2006 12:57 AM |
| How to disable the beep? (ASAP) | Rahxephon | General Yaris / Vitz Discussion | 16 | 06-05-2006 05:03 PM |
