Old 05-30-2006, 11:29 PM   #1
Rahxephon
Drives: Vitz RS
How to disable the beep? (ASAP)
Hey all,
Whenever I put a large backpack in the front passenger seat, a seat belt warning light would come up; after a while, a very loud beep would go/come ON - suggesting that a car is in need of service. I think the car thinks of a large backpack as another passenger (who should be wearing a seatbelt), or maybe a small child (who's not supposed to be sitting in the front).
I'm moving to another city tomorrow and I will be putting lots in the front seat, so is there a way to disable that beep? Any helps will be really appreciated. Thanks in advance,
Rahxephon is offline   Reply With Quote
Old 05-30-2006, 11:40 PM   #2
foober
Drives: two yaris liftbacks
I had to put the passanger seat belt around a bag of bird food two days ago to keep it from beeping. Just click in the passenger seat belt and the sound stops and all will be well..
foober is offline   Reply With Quote
Old 05-30-2006, 11:44 PM   #3
Basscat
Basscat's Avatar
Drives: 2007 Yaris S Sedan
The quick fix is to run the seatbelt around the back of the seat and buckle it. I think I read somewhere you can have the dealer disable it for you if you want.
Basscat is offline   Reply With Quote
Old 05-31-2006, 12:01 AM   #4
Rahxephon
Drives: Vitz RS
Thank you so much! How come I never thought of that before?
Old 05-31-2006, 01:52 AM   #5
got615
i think if you let the beeping goes for 30 seconds. It will actually stop beeping but the light will still flash.
got615 is offline   Reply With Quote
Old 05-31-2006, 04:32 AM   #6
DARK505
Drives: Subaru Impreza WRX
Simple fix... dont put anything in the front seat!
The seats are equiped with sensors that detect how much the "person" weighs, how far back from the airbag they are, how fast you are going, etc... and would actually tighten the seatbelt for a fraction of a second before loosening a little to lessen the impact of the airbag in case of accident. Saftey feature of the yaris. I dont think thats a "service engine/car" signal its more of a "fasten your seatbelt" signal...
Talk to the dealer if you do not want that safety feature... they should be able to do something...
DARK505 is offline   Reply With Quote
Old 05-31-2006, 06:46 AM   #7
Jord
I started a thread about the same thing. You may have a hard time getting the dealer to disable it. They are reluctant because of liability issues. I know there is a way to do it, using the trip button reset meter and clicking, unclicking seat belts, but the chicken dance for other toyotas (i.e. corolla, camry, etc.) doesn't seem to work in the 2007 yaris. I've tried it a billion times. If the dealer tells you how to do it PLEASE POST IT! The only other idea i've had is that the odometer computer manipulation doesn't become active until after you have driven 8000 km and have had to reset the service reminder light. (just an idea) Anyways, good luck and keep us informed. I too am tired of having to keep the passenger seat buckled up, a real pain in the ass. Other than that, I love my Yaris!!!
Jord is offline   Reply With Quote
Old 05-31-2006, 07:27 AM   #8
punch
punch's Avatar
yep the dealer can shut of the buzzer with his scan tool.
Old 05-31-2006, 09:39 PM   #9
KSIbucky
KSIbucky's Avatar
I really read everybodys post but the BEAPING WILL STOP AFTER LIKE 30 TO 60 SECONDS just so you no also it easy just unplug the weight sensor
Old 06-01-2006, 09:46 AM   #10
Ziv
It's all about VVTI
Ziv's Avatar
Drives: Yaris 5Dr LE White
Yeah i heard about that when I made another post sometime ago. It's regarding I put my watermellon up front and some suggest I should put seatbelt for my watermellon. Where in exactly location is the weight sensors under the seat?
Ziv on Vitz '06.
Ziv is offline   Reply With Quote
Old 06-01-2006, 12:44 PM   #11
punch
punch's Avatar
umm isn't there like 5 sensors, and unhooking them will throw an srs airbag light and code...
Old 06-01-2006, 05:02 PM   #12
DARK505
I beleive that is correct. Im not sure where they are located tho... some i would assume would be inside the seat while some might be attached to other electronic packages such as the speedometer... depending on which sensor it is.
Old 06-01-2006, 05:16 PM   #13
SmellyTofu
好多人&
Drives: .
Why not put the bag on the floor area? or belt up the bag if it's on the seat. Nothing worse than the bag flying onto the floor when you do a sudden stop.
Old 06-01-2006, 06:45 PM   #14
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Just curious but why have the weight system disabled or removed just for cargo? Doesnt that imply that if disabled your passenger airbag will not go off? Sucks to be your passenger if thats the case.
mikeukrainetz is offline   Reply With Quote
Old 06-01-2006, 06:57 PM   #15
Tanabe USA
Drives: Toyota Vitz
This has been a remedy among many of Toyota's newer vehicles (Matrix, Corolla, Lexus IS, etc.) It may or may not work on the new Yaris:
1. Turn key to on position, but do not start the car.
2. Make sure the odometer is displayed and not Trip A or Trip B.
3. Turn key to off position.
4. Turn key to on position.
5. Quickly press AND hold the odometer button down for 30 seconds after step 4.
6. While still holding the odometer button, buckle up and then unbuckle.
7. Odometer display will change to "b ON".
8. Let go of odometer button, and it will change to "b OFF"
9. Wait for odometer display to return back to normal.
Enjoy!
Tanabe Racing Development USA, Inc.
"We engineer performance!"
http://www.tanabe-usa.com
Performance parts for the Yaris/Vitz available 6-17-06. Please check forum or email us at info@tanabe-usa.com for updates and information.
Tanabe USA is offline   Reply With Quote
Old 06-02-2006, 06:38 AM   #16
punch
punch's Avatar
Enjoy!
nothing in the shop manual mentions this trick...
Old 06-05-2006, 05:03 PM   #17
Rahxephon
Drives: Vitz RS
Thanks all,
I tried the methods suggested by foober & Basscat. They kind of worked. There is no more beep, just the passenger airbag OFF light showed up instead.
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
Day time Running light....how to disable? Polar_Yaris DIY / Maintenance / Service 33 01-27-2009 06:02 PM
