Old 06-10-2018, 01:37 AM   #1
hmsailor
Drives: 2015 yaris hatchback
DRL disable
how do i disable the DRLs on a 2015 Yaris Hatchback LE? I viewed the 2007 yaris video but no luck. I removed and checked under the steering wheel assembly towards the stereo but nothing. The fuse wont budge at all.
hmsailor is offline   Reply With Quote
Old 06-10-2018, 04:14 AM   #2
RicStyx
Drives: 2012 Toyota Yaris 1.3 -3rd Gen
If you have found the fuse for the Drl lights, then pull it out. It may seem like it won't come out but a fuse is still a fuse and is designed to be replaced. It could be tight. If the small grab tool doesn't work, try a nose pair of pliers and carefully grab and pull it out.
Sent from my SM-N910F using Tapatalk
RicStyx is offline   Reply With Quote
Old 06-10-2018, 09:02 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
There are no DRL fuse.
Sent from my ONE A2005 using Tapatalk
Old 06-10-2018, 09:06 AM   #4
RicStyx
Are you sure, doesn't seem right, even my family's rav4 has one for the Drl strips.
Old 06-10-2018, 09:13 AM   #5
IllusionX
Maybe for the LED strips, but my 07 doesn't have a DRL fuse and uses the low beam with limited current.
2015 DRL module might be located elsewhere as the interior was completely redesigned.
Old 06-10-2018, 10:06 AM   #6
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
why would you disable the DLRs?
DarkShadowFox is offline   Reply With Quote
Old 06-10-2018, 10:11 AM   #7
IllusionX
I did not. I had them rewired to the fog lamps.
It's technically not legal where I live, but cops don't know.
Old 06-10-2018, 12:31 PM   #8
DarkShadowFox
what you should do is, either hardwire in a power line from a line somewhere with taps that runs the headlights and get the fog lamp button and slap it on your pop out panel.
or get the stalk that has the foglamp switch on it and tap your headlight harness. and or look for your connectors I think the yaris is either prewired or can be wired dont ask me how.
Old 06-10-2018, 12:58 PM   #9
IllusionX
Pull handbrake, start car, DRL are off. Release handbrake, then fogs turn on. I can switch it off as I wish.
Turn on the headlights, and fogs turn on or off as it should, and turn off automatically on high beam.
Old 06-10-2018, 05:11 PM   #10
DarkShadowFox
yeah so why did you disable the DLR's again.
Old 06-10-2018, 05:15 PM   #11
IllusionX
Not disabled. It's always running as it should, cept they are on the fogs instead of low beam.
Old 06-11-2018, 10:42 AM   #12
hmsailor
method doesnt work on mine. once i release the handbrake, drl lights come back on.
Disable DRL on 2012 Yaris Le ucsmfu Third Gen Yaris General Discussion 12 09-16-2015 11:29 PM
enable DRL at Yaris 2009-2011 Ot_tO DIY / Maintenance / Service 6 06-15-2012 06:13 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 11:59 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 07:37 PM
Disable DRL and keep Fog Light function!! chino_potato DIY / Maintenance / Service 10 06-23-2007 02:01 PM
