Old 06-12-2012, 10:02 PM   #1
Ot_tO
Drives: Look Signature... ;-)
Question enable DRL at Yaris 2009-2011
Hi,
I have the car description of my car in my signature...
It's a german version.
My car have no automatically DRL.
I asked Toyota Germany because of this - and they said they have no recommendation for the Toyota auto repair shops how to enable it.
And they have no idea which accessories market DRL module could be well.
Maybe someone of you have an idea how to enable the automatically DRL at my car?
If this is not possible, maybe because of the for Germany built cable tree...
Which accessories market DRL module you would recommend which I could install?
As far as I know, the DRL module must switch on the complete running lights.
This means the low beam and 'city light'? (if I park the car in darkness on the street) at the front and the tail light and license plate light at the rear - all 100 %, not dimmed (oh nice german road traffic regulatory approval ).
Thanks
Best regards!
YARIS II (XP9F) Facelift (2009-2011) 3dr Executive 1.33 (74kW/101PS/99hp) 6gear-MultiMode Jan/2010 (german version)
Ot_tO is offline   Reply With Quote
Old 06-12-2012, 10:40 PM   #2
Looking at the European Yaris wiring diagrams, there are significant wiring difference between one with and one without DRLs. That would not make it practical to add the Toyota DRL module since you would have to change the harness.
The easiest way to have DRLs would be to do my "headlights off with the ignition" modification, which allows you to leave the headlight switch on, but the lights turn off automatically when you turn off the key:
http://www.yarisworld.com/forums/showthread.php?t=14427
Old 06-14-2012, 05:22 PM   #3
Ot_tO
Smile
'The easiest way'? ...for you.
If I would tell the mechanic in the Toyota repair shop what he should do... - if I could tell him...
Maybe an aftermarket DRL modul is available what he could install?
To now I couldn't find one.
Thanks
Best regards!
Old 06-14-2012, 09:09 PM   #4
Ot_tO
Smile
Thanks
But I wanted 'just' that the original running light (low beam + tail light and so on) will be switched on if I drive.
No extra LED-DRL installation.
To now I think this will not seen well enough. The installed headlights are bigger and from far the light is seen better.
But, you could tell me that the other way would be better...
If you have one day the possibility and time to make two pictures from far - one with original headlights - and then one with LED-DRL - so we could compare...
This would be super if possible (this would help me much) - but it's also O.K. if not.
You have the Philips DRL8 installed? Self made?
(By the way, your first message - welcome! )
Best regards!
Old 06-15-2012, 05:13 PM   #5
Ot_tO
Thumbs up
Thank you very much!
For a few minutes I started a poll: DRL: Low beam or -lamps - or not?.
Please could you post your pictures there then?
Thanks
Best regards!
