Old 11-10-2014, 09:02 AM   #1
gabriel2012
Drives: 2011 Base Sedan
Best way to avoid having your yaris stolen?
Right now in PR there have been about 150 toyota yaris vehicles stolen this year. The main reason is people buy this car more than any other vehicle in the island and theres plenty of demand for its airbags/engine/trans.
Right now I have a base power nothing sedan, I always park close to the security guy at work and keep it inside my yard when I'm home. Every time I park I lock the steering wheel and use "The Club". Also, I make sure the red bulb comes on as I walk away from the car.
Is there any good aftermarket alarm that suits the yaris well? I was thinking of a viper but don't know which model to pick, I plan on adding aftermarket power locks to it.
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too!
gabriel2012 is offline   Reply With Quote
Old 11-10-2014, 09:28 AM   #2
The flashing red light indicates that you have the engine immobilizer, which requires the transponder key to start, making it quite a bit more difficult to steal your car.
The question though is how Yaris are stolen down there. If they are nabbed with a tow truck to take them away and part them out, then an alarm may be worthwhile.
Old 11-10-2014, 09:29 AM   #3
gabriel2012
Mines doesn't have the immobilizer(no ring on ignition), the red light is the basic alarm. They are mostly being stolen by people breaking in/hot wiring them.
Old 11-10-2014, 09:44 AM   #4
OK. The engine immobilizer is definitely a better deterrent than a basic alarm. The non immobilizer Yaris are incredibly easy to hot wire. One very effective old school trick is to wire a hidden key (or even just toggle) switch in line with the starter wire, making the connection way up under the dash, so that it can't be traced without fully removing the upper dash assembly.
Old 11-10-2014, 10:03 AM   #5
gabriel2012
like an old school kill switch?
Old 11-10-2014, 10:17 AM   #6
Exactly
Old 11-11-2014, 09:07 AM   #7
gabriel2012
Exactly
I got the switch installed. Its a hidden small button. When I put the key in the ON position it wont start and looks like:
When I push the hidden button it looks like:
Local shop charged me $30 to install. So far its working great, the guy put some sort of relay between the button and the car wiring(sorry not to familiar with wiring)
Old 11-10-2014, 10:19 AM   #8
gabriel2012
I'm not too savvy when it comes to car wiring, but ill see a local shop on installing one. Thank you scott!
Old 11-10-2014, 10:27 AM   #9
Kar98
Drives: 2011 Scion tC
Don't use "the club". It's in fact counterproductive. All it does is tell people that's the only security measure taken. So you see "the club" from afar, you know there's no advanced anti-theft protection, all you have to do is saw through the steering wheel, use the club as a lever to break the steering wheel lock and throw the club away.
Also, it won't help you if your car just gets lifted on to a flatbed to be stripped of parts later.
Old 11-10-2014, 11:46 AM   #10
gabriel2012
I use it simply because there are a large number of yaris in parking lots I frequent, when a potencial thief shops for a victim, he will most likely pick the yaris without the club since it would be a quicker getaway.
For example there are 52 cars at my work parking lot, 14 of those are yaris HB/Sedans.
Old 11-10-2014, 12:34 PM   #11
nortonfb
Drives: 2007
Leave a note on the drivers window, inside which reads "snake got loose, back in ten".
Friend that worked at the local pd used that for years. The locals would break into the lot & steal the cars belonging to the PO's.
Norton
nortonfb is offline   Reply With Quote
Old 11-11-2014, 11:51 PM   #12
nookandcrannycar
What a bunch of morons! Did they usually get caught?
Old 11-10-2014, 01:24 PM   #13
NEexpat
Drives: 2009, auto, 4dr LB
What about something like this HERE
Not a true anti-theft per se, but could be very effective.
I've read about these devices in general and I can't speak to the quality of that particular brand, just listed it here as an example.
NEexpat is offline   Reply With Quote
Old 11-10-2014, 01:56 PM   #14
gabriel2012
thats neat but 99% of all stolen yarii have ended up totally ripped apart and burned within hours of being stolen.
I went to an alarm shop(thinking of installing an aftermarket with door lock actuators) and they offered to install a hidden kill switch at no charge. total for install on all 4 doors would be $250
Old 11-10-2014, 02:31 PM   #15
CoryM
Drives: 2009 5-door, 5-speed
As CTScott suggested, sometimes a simple switch or two is all it takes.
On my old, modified camaro (unbelievably easy to break into and hotwire) I installed a starter switch that required you to have the fan position lever pushed all the way over to crank the engine. And I installed a button switch that killed the power to the IGN coil if you pushed on a certain spot of the console. Totally invisible, and way harder to steal.
Old 11-10-2014, 03:11 PM   #16
NEexpat
Completely understand, I believe that some of these have the facility to alert you if the vehicle moves outside of a predefined area.
Ultimately a well hidden or disguised (CoryMs Camaro= very clever) kill switch, as has been mentioned, is probably your best bet and should be relatively inexpensive.
*I do recall years ago when kill switches were becoming more popular reading that some garages who did the install were working in concert with the car thieves, so if you do go that route and not do it yourself, chose a reputable place.
I like the double switch idea, belt and suspenders, rub your stomach, pat your head sorta thing..............................huh what? Sorry.
Cheers.
Old 11-10-2014, 04:25 PM   #17
gabriel2012
Cheers.
I totally understand, but its a reputable shop, I've had car stereos installed for all of my cars there and they are pretty well known in town.
What I'm thinking off right now is where Im going to place the switch.
Old 11-11-2014, 09:28 AM   #18
bronsin
bronsin's Avatar
Makes a lot of sense. Normally I advise people NOT to install aftermarket alarms and such. Not only is the Yaris not terribly sought after these aftermarket devices cause TONS of problems as any reading of posts to this and other websites having to do with cars or motorcycles will quickly confirm.
But this sounds like a great idea. Of course if they have a flatbed it wont help. But there are ways to protect against that too.
I know people who are from PR and I understand yes your Yaris could be stolen there. (and of course there are other places with the same problem)
I wish you luck with your $30 fix and hope it helps others.
BTW this might be a good time to mention some other of my suggestions like NEVER WASH YOUR ENGINE WITH A HOSE!!!
(or someday it might not start and costs $$$$ to fix it!)
(I know it sounds like "Why would someone do THAT!?!" but it happens...)
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
