Old 06-17-2019, 12:58 AM   #1
toyotavios_11
Drives: Toyota Vios
Rpm drop fast after letting off throttle pedal
My car is 2007 model sedan with 1NZ-FE mated to U340 4AT.
Recently I notice that when the car is speeding up from 15km/h to 60km/h while the gear is at the point of time in 2nd or 3rd position, the moment I let off the throttle pedal, RPM needle will drop fast from 2000+ RPM to around 1000 RPM then surge a bit up to around 1200 RPM. I can hear there is a minor shock noise from the front and feeling a little bit of jerk.
While the gear is in 4th gear, either lock up or not, letting off the throttle pedal, RPM will just reduce slowly which I feel this is normal.
What are the possibilities of the problem?
toyotavios_11 is offline   Reply With Quote
Old 06-20-2019, 01:49 PM   #2
seatech30
Drives: Yaris 2008 Sedan
Is it possible the car is shifting into the next gear right around that point? What happens if you let off the gas at say 70km/h or 50km/h vs the 60km/h?
How's your trans fluid level?
seatech30 is offline   Reply With Quote
Old 06-30-2019, 07:22 AM   #3
toyotavios_11
Drives: Toyota Vios
have no idea. perhaps i should perform fluid change.
Old 06-30-2019, 03:01 PM   #4
johnwk
Drives: 2010 Yaris LB
There's a transmission fluid dipstick. Just check it while the engine is warm and idling, and take note of the color on a paper towel.
johnwk is offline   Reply With Quote
Old 07-07-2019, 02:30 AM   #5
toyotavios_11
Drives: Toyota Vios
fluild level is at correct level.
btw, i have solved the problem by cleaning MAF sensor.
Successful 1ZZ Throttle Body Swap rabbito Performance Modifications 34 10-15-2024 08:12 AM
HELP: Yaris Matic Idle RPM Drop PlainAndrew DIY / Maintenance / Service 4 07-20-2016 05:04 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 05:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 04:10 PM
3 Drive Throttle Contoller by NTD Sabretooth Performance Modifications 31 10-07-2010 01:12 PM
