Old 07-16-2016, 11:45 AM   #1
PlainAndrew
Drives: Yaris 1.5 S-Limited
HELP: Yaris Matic Idle RPM Drop
Hey guys, I joined the forum because I have been facing this in solve problem with my car.
My car is a 2010 Toyota Yaris 1.5L
The problem is when ever I'm in Drive than hold the break the rpm will drop to 500 and shakes the engine. This also happen during neutral it sometime drops to 500. Especially with the ac on.
Is there any solution on how to fix this?
Thanks
PlainAndrew is offline   Reply With Quote
Old 07-17-2016, 07:29 AM   #2
Try cleaning your throttle body.
Old 07-19-2016, 01:21 PM   #3
esse10
Drives: 2009 yaris 2 door
belt
tighten the serpentine belt. Since this cars don't have an automatic belt tensioner the belt get's loose after a while. Mine used to do the same whenever I had the engine at Idle it would bog down on the rpm and almost die. Didn't do it anymore after tightened up the belt just don't over do it.
Old 07-20-2016, 06:08 AM   #4
PlainAndrew
Thanks for the input. I have done the following since my post:
- Clean Injectors
- Clean TB
- Carbon Clean
- Clean MAF
- No vacuum leak
Yet I still get the vibration and rpm drop during idle. I will try to tighten the serpentine belt.
Is there any other solution?
Old 07-20-2016, 04:04 PM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
normally with AC turned on the car should rev up.
Is your car battery good? my battery was really bad and i would have bad idling (manual transmission)
Check out my Build thread:
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
Just bought a new Yaris Connoisseur_of_fine_cars General Yaris / Vitz Discussion 46 09-10-2011 10:49 AM
