Old 10-22-2019, 04:13 PM   #1
scoobopdan
Drives: 2008 Yaris
MAF check engine light
Long story short - had a cold air intake on my 08 yaris for 4 years. Had to restart the battery when I first installed it and it had no issue relearning. Had an oil change 3 weeks ago and had the mechanic put on a new filter while it was lifted. He didnt put it on all the way and it fell off, but I caught it after a few miles. Put it on correctly, cleaned the MAF, and reset the computer. Now the MAF is throwing a check engine light randomly but will turn off after the car being off for a while. It's done this 3 times. It always trips while on the highway going up hill. Should I get a new sensor? Any idea what could be causing this?
scoobopdan is offline   Reply With Quote
Old 10-22-2019, 05:06 PM   #2
Make sure the MAF is seated correctly and you haven't damaged the o-ring.
Old 10-22-2019, 07:50 PM   #3
scoobopdan
Drives: 2008 Yaris
By o-ring do you mean essentially a gasket between the sensor and intake?
I should note that the idle and gas mileage haven't changed and I can't hear any interruptions in the engine noise, even when the light trips.
Old 10-23-2019, 01:57 PM   #4
B.B._07
Drives: 07 5dr
What is the code? There's more then one MAF related check engine code. MAF sensor's (especially OE quality ones) can get quite pricey so I wouldn't go buying a new one unless you're certain it's the problem.
Old 10-23-2019, 04:41 PM   #5
komichal
Did you clean the MAF with proper MAF cleaner spray?
Old 10-26-2019, 02:05 PM   #6
scoobopdan
Drives: 2008 Yaris
I did clean it with proper MAF cleaner. The exact code is P0101. How would I know if it wasn't seated properly? It seemed to reinstall after the cleaning like normal.
Old 11-01-2019, 03:59 PM   #7
scoobopdan
Drives: 2008 Yaris
I reset the computer, really cleaned the MAF again and let sit for a longer time to dry, and let it idle for a good 10 minutes after the reset. So far no check engine light, will keep posted.
Old 11-03-2019, 01:45 PM   #8
bronsin
bronsin's Avatar
I got a rebuild maf From Napa about eight years ago for $80 for my sons 2000 and echo. Same part on the Yaris. It still works so if you need a new one no biggie.
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 07:17 PM
Cold air intake....check engine light on...??? JohnnyMalice Performance Modifications 4 04-29-2012 10:46 PM
Differntial diagnosis for the check engine light yaris sedan dante2086 DIY / Maintenance / Service 1 12-18-2010 10:04 AM
Check engine light Mr Yarisman Performance Modifications 7 10-25-2009 12:10 AM
