Old 10-24-2009, 02:08 AM   #1
Mr Yarisman
Mr Yarisman's Avatar
Drives: Vitz
Check engine light
I change my stock air filter to AFE 51-1130 intake.why my check engine lights on?
Mr Yarisman is offline   Reply With Quote
Old 10-24-2009, 02:31 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Make sure it's installed correctly and run the car as usual and wait for the ECU to adapt.
Old 10-24-2009, 03:00 AM   #3
YarisSedan
Drives: 08 Yaris Sedan
Probally loose connection resulting in vacuum leak. Or the seal for the MAF sensor is not seated correctly. If the CEL is on its most likely MAF sensor related. I would wiggle all the hoses and tighten the clamps. Make sure the breather hose is connected correctly to the tubing and if everything looks good disconect the negative battery for a few minutes and reconnect and seeif they light comes back on. If it does you may have damaged the sensative MAF sensor. You can never touch the wires or get any contamination on them.
Old 10-24-2009, 03:21 AM   #4
Mr Yarisman
Drives: Vitz
When i install the AFE intake the engine lights came on then I drove it for day then came off now is on again.
Old 10-24-2009, 11:46 AM   #5
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
If you're going to mod your car, you should invest in a OBDII code scanner. You can pick one up easily under $100. Use it for your own CEL or impress your friends...
RUFFSTUFF is offline   Reply With Quote
Old 10-24-2009, 09:50 PM   #6
Mr Yarisman
Drives: Vitz
What's the good OBDII code scanner?
So Cal
Old 10-24-2009, 10:44 PM   #7
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Scangauge II i presume?
Old 10-24-2009, 11:10 PM   #8
RUFFSTUFF
I have a Actron CP9135 AutoScanner Diagnostic Code Scanner and a Hypertech tuner with a OBDII scanner built-in. The Actron works great and is probably the most common one found at auto parts stores... It's about $140 but you can find it for cheap on EBay and I've used it on several different vehicles. Remember OBDII is the standard for all cars sold in the US for 1996-up model years.
Check engine code 456 on brand new '09 kameele DIY / Maintenance / Service 3 10-14-2009 11:12 PM
Got engine check light :( jmew0ng DIY / Maintenance / Service 15 07-01-2009 10:09 PM
Anyone get the Check airbag light to go away when you installed racing seats or wheel wholenizz Cosmetic Modifications (Exterior/Interior) 1 06-17-2009 08:14 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
