Old 10-14-2009, 01:06 PM   #1
kameele
Drives: 2009 Zephyr Blue manual sedan
Check engine code 456 on brand new '09
Got to work this morning and realized the CE light was on after only 1400 miles . i know a lot of cars this means that the gas cap wasn't tight. since I had filled up last night, I checked this and then tried again and it's still on. the local dealer said he couldn't look at it until friday, so I went to a VIP and they read the code. I then talked with a service guy at the dealer where I got it (not near work) he said if it is the gas cap and it's now nice and tight, it may take a couple days to clear. Something about a vacuum pump that gets checked a couple of times a day and its sensor that has to be happy for a few times after it's detected a leak Sure don't know much about how all that system works. does this sound like the way it should work? he did say that nothing in that code will hurt the car short-term, but to get it checked if it doesn't go away in a couple of days.
Thanks for any info.
kameele is offline   Reply With Quote
Old 10-14-2009, 02:32 PM   #2
frownonfun
frownonfun's Avatar
did you try unhooking the battery to clear the code?
if that doesn't work i would just take his advice and give it a few days.
I crush you like tiny clown car, because you are clown, yes?
Old 10-14-2009, 09:40 PM   #3
It takes two successful drive cycles for it to clear itself. A drive cycle is >40MPH for >3 minutes.
Old 10-14-2009, 11:12 PM   #4
kameele
Thanks for that. hopefully on the way home from work it will be gone. if not, i guess i get to see how nice the service folks are at the dealer.
ODB2 Check engine code reader Arkhangel Performance Modifications 11 02-25-2009 04:13 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
