![]() Drives: JDM Toyota bB NCP31 Join Date: Oct 2020
ECU Tuning 1NZ-FE ignition timing and fuel ratio (Airflow / Injector)with Emanage Blu
Hello guys, I am from Hong Kong tuning a JDM Toyota bB NCP31 (Scion xB 1st Gen) with 1NZ-FE for ignition timing and fuel ratio using the Emanage Blue.
I am boosting with turbo (Kinugawa Turbocharger TD04L-15T) at max 0.6 bar (8.70 psi) Here are few question I would like to ask: 1) Is there any thorough guide on how to tune with the Emanage Blue? After learning a little about EFI tuning & how emanage blue works, feel like tuning this piggy back is like a guess work. 2) Ignition Timing I have read that some guy in this forum with his Yaris tune without modifying the stock ignition timing, would this work well? If not, how do I tune with emange blue to avoid knocks? since I do not have the stock ECU ignition angle map; how do I know how retard of timing should I start for each cell for the tune? So I can start advancing the time from there avoiding knocks. 3) Airflow tuning vs Injector tuning Seems to me that tuning the fuel flow rate to the engine tune in 2 ways for emanage; the first being adjusting the MAF reading the second one is modifying Injector flow rate directly. If I am in a close loop; I should tune with the Airflow reading tune only and avoid Injector tuning right? So I can avoid the stock ECU from "rectfying itself" Last edited by csk457; 10-16-2020 at 01:00 AM. |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 04:07 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
