Old 08-11-2021, 12:55 AM   #1
Rob888
Drives: 2010 Yaris 2 door hatchback
Is it better to drain transmission cooler when changing fluid?
I am about to do a drain and fill on the transmission on my 2010 Yaris.
From what I have read, by detaching the transmission cooling hoses where they attach to the tranny another quart or so of fluid drains out of the tranny cooling portion of the radiator.
It would be better to drain the tranny cooling portion of the radiator in order to replace more fluid, correct? Would draining the tranny cooling portion of the radiator create any complications? Do I need to operate the tranny to get the drained fluid back into the cooling portion of the radiator and then add more fluid? Thanks for any replies.
Rob888 is offline   Reply With Quote
Old 08-11-2021, 08:47 PM   #2
ex-x-fire
I'd just drain and drive and drain again.
Automatic Transmission Fluid - Drain and Fill vinny121 DIY / Maintenance / Service 5 04-07-2022 07:48 AM
Manual Transmission Fluid Woes tmontague Performance Modifications 4 10-08-2018 10:12 AM
Amsopil transmission fluid two thumbs up! Toolaholic DIY / Maintenance / Service 5 09-11-2015 12:35 PM
changing transmission fluid (automatic) caineroad General Yaris / Vitz Discussion 4 07-18-2012 02:35 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
