Old 07-17-2012, 03:07 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
changing transmission fluid (automatic)
I did a transmission fluid change in May, everything is good. But I heard some poeple say I need to change twice or even the third time to get rid of all the old oil. Is this necessary? If so, how long should i wait between each change?
Thanks
caineroad is offline   Reply With Quote
Old 07-17-2012, 03:13 PM   #2
bronsin
bronsin's Avatar
If you just dropped the pan and drain it from there you only got 2 0r 3 quarts of the ~8 that are in there.
You could do that a dozen times and not get it all.
Some shops have the setup to get it all and it involves hooking up to the transmission lines that run to the radiator (or something) This pumps the new stuff in while pumping the old stuff out and is about the only way to "change' the oil in it.
Which isnt necessary unless you drive under really adverse conditions.
Im not sure it is even then.
Old 07-18-2012, 11:10 AM   #3
bronsin
bronsin's Avatar
Ok then tell me how many quarts of oil in that thing?
Old 07-18-2012, 01:35 PM   #4
caineroad
caineroad's Avatar
Thanks guys, I asked my dealership they said it only needs to be changed once, and yes about 3 quartz.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 07:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
