Old 08-26-2021, 11:20 AM   #1
supercoolguy
Drives: Yaris sedan
Help - Transmission Grinding/scraping noise while in gear
'08 Yaris Sedan
Manual
~200,000 nearly all freeway miles
The condition
A "grinding" or "scraping" noise, or maybe both at the same time, that comes from the transaxle/drivetrain (no discernible D vs P side difference)
The noise is only noticeable in gear. All gears. No noise in neutral or with clutch depressed
Loud enough to be noticeable over road/tire noise below 40 MPH. Not noticeable at freeway speeds
The noise is probably more noticeable/worse in mild overrun.... although that may just be the fact that at higher RPM engine braking (eg down hill), I cant hear it
No gearshift issues (all smooth/easy shifts, no slups, etch)
No performance or mileage issues (30 MPG in extreme, agressive, heavy stop go hilly-driving city traffic with AC, 35 in mixed, 39~40 in pure freeway)
Brand new Redline gear oil (no evidence of abnormal metallic debris or low fluid level in old oil)
NOTE: the noise/symptom was evident prior to the fluid change
My assumption is that its a bearing in or associated with the clutch/flywheel, and that repair and diagnosis will require transmission removal.
I dont know a lot about the transaxle operation, but I assume that because the noise is only evident with a gear engaged, but also ALL gears, that its unlikely to be anything down-stream of the clutch
I should be able to post audio soon, but I just wanted to get this on the site ASAP
If anyone has any advice please let me know.
If anyone reading this thinks that it is the transaxle internals, please suggest a West Coast supplier of rebuilt Transmissions (Northern CA, OR, or WA)
I did a cursory search and the prices are insane.
supercoolguy is offline   Reply With Quote
bearing, clutch, flywheel, transmission
Smooth gear transmission AnaKara DIY / Maintenance / Service 4 07-30-2019 11:25 AM
Yaris Automatic Transmission squeal from second to third gear. sackville ns General Yaris / Vitz Discussion 3 03-11-2019 11:04 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
Transmission noise The little red pill General Yaris / Vitz Discussion 11 05-15-2009 02:26 PM
