Old 03-11-2019, 11:01 AM   #1
sackville ns
Drives: 2007 Yaris
Yaris Automatic Transmission squeal from second to third gear.
Hi All
First post. Be nice to the newbie lol
2007 four door yaris automatic. 340 000 km. Transmission fluid has never been changed, just topped up.
When driving normal, i mean like a grampy, just regular shifting with no issue.
When hitting the gas hard it shifts normal from first to second and then it makes a loud squeal from second to third or third to four. Sounds likes bad bearings in the alternator. It hard to describe.
The noise has been there for the past 50 000 km.
There is no transmission slippage.
Thanks in advance.
Alan
sackville ns is offline   Reply With Quote
Old 03-11-2019, 11:48 AM   #2
Toyota Canada recommended service on transmission is flush and fill every 100,000 kms. You are due!
As for the squeal, hard to say. A bearing issue would not manifest itself in that manner. It would be an ever present noise. Most common culprit of a "squeal" is the serpentine belt. Again, it is an odd time for a belt squeal to manifest itself but I would look to it first. Had it ever been changed? It not, it is due. If yes, and within the past few years, then it may just need a tension adjustment.
Old 03-11-2019, 12:26 PM   #3
sackville ns
Drives: 2007 Yaris
Thanks for the reply. I have changed the belt a few times. Usually once a year.
I was trying to describe what the noise sounds like.
Old 03-11-2019, 10:04 PM   #4
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
It's weird that in the US, there's no firm recommendation for when the ATF should be changed. It's basically supposed to be monitored every 30,000 miles and changed as needed. Weird that in Canada, there's an actual recommended service interval for a flush and fill. Wonder why there's a difference.
Hamster is offline   Reply With Quote
automatic transmission, squealing noise
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
yaris automatic transmission lag pbolden General Yaris / Vitz Discussion 7 04-23-2009 10:10 PM
