![]() Drives: 2004 toyota yaris t3 3 door Join Date: Feb 2023
P0171 fault code
Just had a p0171 fault code show couple days ago.
Anybody got any ideas what it might be. |
Your fuel mix is running lean, too much air. Top thing to look at in any google result is the MAF sensor needing to be cleaned.
Maybe the duct between the Maf and the throttle body is torn.
How do you fix code P0171?
You can usually fix P0171 using the following steps: Replace the fuel pump or fuel filter. Change the fuel pressure regulator. Replace the powertrain control module. Change one or more injectors. Replace one or more oxygen sensors. Change the mass airflow sensor. Repair vacuum leak
I’m guessing vacuum leak
code?
Is P0171 serious? Issue Severity: MODERATE– Extended driving with this code can cause internal engine damage. Repair Urgency: Get this code fixed as soon as possible to avoid damage to spark plugs, pistons, and catalytic converters. Diagnosis: It is important to complete the entire diagnostic process when diagnosing P0171.
#8 | |
#9 | |
I’m guessing you have a vacuum leak. Have you consulted Scotty on YouTube? He describes a procedure for locating vacuum leaks. I think it involves spraying something like WD-40 on it around the vacuum lines of the engine and listening for RPM increase. If it increases when you spray It someplace there’s your leak
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
The filter maybe part of the fuel assembly. In the top of the fuel tank.
My 2007 has the filter inside the fuel pickup assembly on the top of the fuel tank. |
Sometimes the fuel filter is integral to the fuel pump
| Getting a P0171 code even after taking it to the shop | Chip Whitley | DIY / Maintenance / Service | 3 | 01-30-2021 10:24 AM |
| SRS B1653 fault code | CB900F2 | DIY / Maintenance / Service | 3 | 11-14-2018 09:33 AM |
| The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) | Darb | Off-topic / Other Cars / Everything else Discussions | 86 | 10-18-2017 09:03 AM |
| Yaris CDX 1999 P0171 error code | Davax | DIY / Maintenance / Service | 2 | 08-18-2010 08:14 PM |
| error code P0171 | bronsin | DIY / Maintenance / Service | 17 | 03-12-2010 07:22 PM |
