Old 03-08-2010, 04:58 PM   #1
bronsin
bronsin's Avatar
error code P0171
Got this error code on my sons 2000 ECHO. Assume there is enogh commonality with the Yaris to make deductions valid. Book says P0171 can be:
air induction system
injector blocked
mass air flow meter
engine coolant sensor
fuel pressure
exhaust leak
opn/short heated oxy sensor bank1 sensor 1
heated oxygen sensorr
Anyone have any experience with this code? Or have any comments on how to evaluate each component listed? Im thinking its easy to check for exhuast leak.
Old 03-08-2010, 05:59 PM   #2
1stToyota
1stToyota's Avatar
injector blocked
mass air flow meter
fuel pressure
exhaust leak
Did one last week (P0171/P0174)...but it was on a Ford Windstar (front valve cover, PCV valve, isolator bolt kit & intake manifold gaskets)
On the 2000 Echo I think I'd start with a quick look at the MAF meter to see if it's dirty.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 03-08-2010, 06:10 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
wow... if he's having issues with the MAF then there's something way wrong with the air filter.... correct?
Old 03-08-2010, 06:16 PM   #4
1stToyota
1stToyota's Avatar
Originally Posted by talnlnky View Post
wow... if he's having issues with the MAF then there's something way wrong with the air filter.... correct? One of those OBDI Karman Vortex Air Flow Sensors that an ex YW member said we had on our Yaris'? Seemed like a few other members agreed about the OBDI sensor being on our OBDII Yaris. LOL
injector blocked
mass air flow meter
fuel pressure
exhaust leak
Best place to start
2008 Scion xD
Old 03-08-2010, 07:12 PM   #5
YarisSedan
Drives: 08 Yaris Sedan
thats a system too lean code i believe. Most likely a vacuum leak causing lean condition or MAF sensor that is contaminated. First check for any vacuum leaks. Spraying carb cleaner in areas where you may suspect and listen for changes in idle to locate. Inspect all hoses that go to intake that is behind the maf sensor for cracks or brakes. If none are found then remove and inspect the sensor. Look for dirt buildup. If it is dirty you can spray it with MAF sensor cleaner or electrical contact cleaner and replace the filter if its dirty.
A faulty 02 sensor usually will trigger a code for heater circuit fault. Injectors that are restricted enough to cause a lean condition will usually trigger a intermitent missfire you should have a p0300 code along with it.
Id say the most likely cause is the MAF sensor. Especially if there is a aftermarket intake. Oiled intakes such as K&N have been known to contaminated sensors. The oils get sucked on and stick to the sensor. Then the dirt sticks to the oils and builds up on the sensitive wire.
Old 03-08-2010, 07:29 PM   #6
bronsin
bronsin's Avatar
Thankyou. Thankyou. I checked the exhaust system by plugging the tailpipe with a rag. Seemed good. Checked for loose/cracked hoses all around the af housing and the local area. All good. I bought the car with 116k on it two years ago and put a Purolator AF on it then. Its pretty dirty. Has 133k now. Car has never had a KN on it. The two wires on the MAFS are dirty and rusty looking. One is oily looking. I was going to use brake cleaner fluid on the wires. That wont melt the plastic housing, will it? MAS specific cleaning fluid is $7.
Old 03-08-2010, 07:40 PM   #7
bronsin
bronsin's Avatar
q
Old 03-08-2010, 08:02 PM   #8
krusty
krusty's Avatar
Drives: 2010 Yaris ce
Some of the brake clean products out there can melt plastic you would be safer to buy maf cleaner or something that is safe on plastics.
krusty is offline   Reply With Quote
Old 03-08-2010, 08:24 PM   #9
YarisSedan
Wouldnt try brake cleaner. May be too harsh. Use electrical contact cleaner or MAF cleaner. 7 bucks is worth it for the piece of mind if you damage the sensor they are EXTREMLY expensive. Replaced one on my friends lexus it was 967. Not sure how much they are for the yaris probally atleast a few hundred.
Old 03-08-2010, 09:11 PM   #10
bronsin
bronsin's Avatar
Yikes $967! Im cheap though so I might try just a little on the plastic and see if it melts.
Old 03-09-2010, 08:12 AM   #11
1stToyota
1stToyota's Avatar
I'd use MAF cleaner; last time I checked retail was close to $600.00 for new MAF sensor
2008 Scion xD
Old 03-09-2010, 01:28 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
You're crazy man.
It's $7.00. Less than the cost of indigestion at Rotten Ronnies.
Old 03-09-2010, 07:41 PM   #13
bronsin
bronsin's Avatar
Used the brake cleaner on the MAS with no ill efects. Just sprayed it on and drained it three times. Wires came out nice and clean. Plastic was unaffected. Changed to AF also. Drove the car ten miles then let it sit and idle for half an hour. I erased the CEL with the code reader and it didnt come back on again. Is that long enough?
Old 03-09-2010, 07:58 PM   #14
bronsin
bronsin's Avatar
q
Old 03-09-2010, 09:41 PM   #15
YarisSedan
Will need to drive for about 100 miles to confirm 100 percent its fixed. Have to set all the monitors first. Light still may come on.
Old 03-10-2010, 08:19 AM   #16
bronsin
bronsin's Avatar
Time will tell. I'll post the results whn they become apparent.
Old 03-12-2010, 05:12 PM   #17
bronsin
bronsin's Avatar
Over 200 miles and the light is still out!
Old 03-12-2010, 06:22 PM   #18
1stToyota
1stToyota's Avatar
I think you got 'er.
2008 Scion xD
P0171 MGargano Performance Modifications 14 05-30-2009 01:10 PM
