Old 05-26-2009, 06:30 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
P0171
I swapped my 1ZZ throttle body back to the stock one, and ever since, I'm getting CEL P0171 when I idle for about 5 minutes. Aside from the TB, I haven't changed anything that I think would be causing this. Anyone know of any 'problem' areas to check for a fix to this?
MGargano is offline   Reply With Quote
Old 05-26-2009, 06:31 PM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
unplug the battery negative terminal, turn the headlight stalk on, and wait overnight before re-connecting the battery.
Old 05-26-2009, 06:32 PM   #3
MGargano
The car runs rough (in cycles) at idle. It'll idle smooth, then go through a wave of roughness for a few seconds, then back to smooth, again and again. It's worse with the a/c on. The car has less than 3,000 miles on it, so I don't think it's clogged injectors or MAF or bad o2 sensor...
Old 05-26-2009, 06:36 PM   #4
AlexNet0
AlexNet0's Avatar
did you read my post?
Old 05-26-2009, 06:38 PM   #5
MGargano
Yes, sorry I was posting my follow-up when you posted your reply. I pulled the battery cable and will check again tomorrow.
Old 05-26-2009, 07:39 PM   #6
seth_man
seth_man's Avatar
Drives: 08 Liftback
P0171 is a lean condition. which means your getting not enough fuel or un-metered air into the engine after the mass air flow sensor. double check everything you touched make sure hoses are connected and not broken and i would pull that TB off again and check the gasket. just pulling the battery to clear the code wont repair the problem.
seth_man is offline   Reply With Quote
Old 05-26-2009, 07:44 PM   #7
AlexNet0
AlexNet0's Avatar
have you been following the TB threads? If there really is a problem, then the code will come back, if it simply needs to re-learn the stock Tb again, then it wont. No need to rip everything apart again when there is no certainty there is another problem.
One step at a time.
Old 05-26-2009, 07:58 PM   #8
MGargano
I'm hoping it's just the ECU needing to relearn the stock TB again
Old 05-27-2009, 11:11 PM   #9
MGargano
No such luck. The car idled smoother today than it did before I disconnected the battery, but still rougher than normal. And the CEL came back at idle after driving a few miles. Ideas?
Old 05-28-2009, 02:06 PM   #10
jkuchta
Drives: 2007 Yaris hatch (red)
Look for air leaks....thats more than likely the cause of your problem.
jkuchta is offline   Reply With Quote
Old 05-28-2009, 04:18 PM   #11
MGargano
Any usual suspects for what/where air might be leaking?
Old 05-30-2009, 12:57 AM   #12
MGargano
I switched back to the 1ZZ TB w/ chip swap and adjusted the idle screw... still getting P0171 but the idle doesn't seem rough now.
Old 05-30-2009, 07:11 AM   #13
AlexNet0
AlexNet0's Avatar
I guess make sure that the vacuum lines are all reconnected, I accidentally pulled the vent off of the valve cover once.
Old 05-30-2009, 12:33 PM   #14
MGargano
The engine's idling smoothly now, but I'm still getting CEL P0171... where should I be looking for a possible air leak?
Old 05-30-2009, 01:10 PM   #15
MGargano
Found it! The valve on the Husky filter I'm using as an oil catch can is for shit... leaks air like crazy.
