View Poll Results: What do you think of frame braces | |||
Frame braces work and improve handling of a Yaris. |
1 | 100.00% |
Frame braces are not effective on a Yaris. |
0 | 0% |
Voters: 1. You may not vote on this poll |
![]() ![]() Drives: 2015 Toyota Yaris LE Hatchie Join Date: Oct 2021
Suspension part interchangeability for 2015 5 door hatch back
Hello
Does anyone have any idea about part interchange ability between yaris generations? I have a 2015 and nobody has aftermarket frame braces or strut/ shock tower braces. The pics look the same except for the mounts on the shocks. I would love to start a sticky on parts interchangeability. First example is the sway bar from the 2013. The PTR11-52071 is supposed to bolt right up. I am installing one on my 2015 Le 5 door hatch. What else can I get away with? |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
Pretty much anything suspension-wise from a 2nd gen(06-11) will bolt into a 3rd gen hatchback(12-19).
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's ![]() |
Are the shock and shock mounts the same or different>
Thanks Mitch.
I thought the shock mounts and front strut tower are different (I want to install a strut tower brace.). Last edited by Calrenman; 04-03-2022 at 03:36 AM. |
Gen 3 > Gen 2
I have a Tanabe strut bar ready to go onto my car next weekend when I swap onto my summer wheels and the part number is the same between the NCP91(2nd gen hatch) and NCP131(3rd gen).
Nice
Let me know how it works. I have not purchased the strut bat yet.
I am looking at the "Front Strut Bar for 2006-2020 Toyota Yaris XP90 XP150 1.5 Hatchback Ultra Racing" (link below). Have you had any experience or heard any reviews with this company's gear? ![]() I put a "horn brace" and a urethane suspension on my hatch back 3cyl./5 speed 1998 GEO Metro. It was fun in the canyons here in L.A./ Ventura. 0 to 60 in under an hour! ![]() https://www.ebay.com/itm/11519063749...4AAOSwL2hh4PVT |
#6 | |
Gen 3 > Gen 2
They seem to be fairly decent for one that is non-adjustable. I recommend the Tanabe one, you can adjust it.
What does the adjustment do? Camber? Or just stiffen the ride?
Is the tanabe four bolts or two? Do you have a part # or link handy? I am new to the mods on this car. My car has been in a fender bender so adjustment may be a good call. Car tracks well. I cannot wait to put the sway bar on. The freeway is wobbly in the wind. Thanks for the heads up. |
#8 | |
Gen 3 > Gen 2
Tanabe part number should be: NST45. I got mine from RHDJapan. This link should help you: https://www.yarisworld.com/forums/showthread.php?t=2285
Thank you Mitch.
#10 | |
Did you install the bar yet?
Hello Mitch. Did you install the bar yet?
Is there a difference? Quote:
#11 | |
Gen 3 > Gen 2
Planning a wedding eats up alot of time. ![]() On the other hand, my exhaust came in from Japan so I get to install that too at some point ![]()
You are having a party with that lil car.
did you get a "cat back" exhaust? Good luck with the wedding.
Gen 3 > Gen 2
Yes. I got a Fujitsubo Authorize RM from Japan.
Gen 3 > Gen 2
Here is the strut bar, fits like a glove. Mounting the brackets is a pain, there isn't enough clearance between the bolt and strut assembly for a socket/extension so it requires alot of patience but other than that it fit perfectly. Might be easier if you remove the wiper cowl but I did not.
#15 | |
That looks great. Did it improve your handling?
It looks nice. A whole lot of Quarter turns... sucky! I will probably drop the strut. The 2015s had a recall for the strut bearings. So I will check them. Your car looks good!
Did you "tune" the front end or just put the bar in snug? Quote:
Gen 3 > Gen 2
You're supposed to snug up the bar while the front wheels are still off the ground so thats what I did. IMO its more of a show piece than an "upgrade" for normal driving, it seems to help with body roll when you're cornering hard though, especially coupled with the TRD rear sway bar.
#17 | |
Thanks for the feedback. I think I may do this one too!
I like the look of it. I do ride hard in the canyons here in So. Cal so I might get some bang for the buck!
I installed the sway bar and some rubber spring spacers that firmed the ride up and it tracks completely "true" now.
The slop in the rear axle/ trailing arm is gone! TRD sway bar is the way to go! I also installed a trailer hitch for a bike rack that seemed to stiffen it up too. I may have made contact with a Japanese Manufacturer of frame and body braces for test fitting some braces on the 2015 Yaris 3rd gen with an automatic. It may help get parts lists "UPDATED" and expanded. I will go to their shop at the end of the month. I will figure how to get pictures and video up to share results. |
Thread Tools | |
Display Modes | |
DIY - Carbon fiber wrapping | Brian | Wash, Wax, Detailing, Exterior Repairs | 15 | 07-10-2016 12:34 PM |
WTB: Stock exhaust back part thing | hasher22 | Australia | 6 | 04-23-2010 06:53 AM |
NEED HELP - Yaris suspension part | Trish | General Yaris / Vitz Discussion | 10 | 11-07-2009 01:44 PM |
Back hurt? | yarswiss | Off-topic / Other Cars / Everything else Discussions | 10 | 11-14-2008 04:39 PM |
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
