Old 11-21-2014, 08:55 PM   #1
vrizrak
Drives: 2007 Yaris Sedan
Weird noise -- please help!!! -SOLVED-
I've got 2007 Yaris with 91,000 ml. I had a vibration in D (it's Auto). No check engine light or error codes. So cleaned TB and MAF. I'm not sure if that noise was before but I definitely start noticing now. It sounds like something lose or just spinning inside. Is this normal? I uploaded short video on youtube. Please see on 45 sec.
https://www.youtube.com/watch?v=GF3IxKL9m1I
Please advise.
vrizrak is offline   Reply With Quote
Old 11-21-2014, 10:06 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
It's pretty hard to tell much from that video. The mic seems to be picking up normal noises and making them sound worse than they are. It's normal to have some minor tick tick tick noises from the valves and injectors, but if you are getting knocking noises it's probably not good. If the noise is a metallic scraping noise, you may want to remove your drive belt and check. If the noise is gone, it's probably the waterpump impeller (usually they leak coolant prior to being that bad though).
If you can't get anywhere, try taking another video a little further away and I will listen again.
Cheers.
Old 11-21-2014, 10:06 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Sounds normal to me.
Old 11-21-2014, 10:21 PM   #4
vrizrak
Cheers.
I will try to get another video on different phone. I think I heard metallic noise. How can check if it waterpump? I'm not sure if I understand correctly. Remove drive belt and run engine to see if noise comes up?
Thanks!
Old 11-22-2014, 08:34 AM   #5
vrizrak
Took another shot. Now I'm thinking that's water pump? https://www.youtube.com/watch?v=1j1nWrjVGDE
Old 11-22-2014, 12:44 PM   #6
catalin
Drives: yaris
The same noise I've noticed that yaris was making but after a couple of days the sound had suddenly disappeared
catalin is offline   Reply With Quote
Old 11-22-2014, 01:28 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I hear something around 0:15 in the video.. and you say it's in drive while you're taking this video?
Old 11-22-2014, 02:15 PM   #8
vrizrak
No that was in "P" on idle. In drive a had a vibration. Looks like vibration is gone after I cleaned TB and MAF.
Old 11-22-2014, 05:44 PM   #9
IllusionX
Again... Sounds normal to me.
Old 11-22-2014, 05:55 PM   #10
ex-x-fire
Take a long screwdriver (or even a wooden dowel) & place it at the accessories & the other part to your ear. The sound should transmit loudly on the noisy part. Or Remove the belt & feel for loose wobbly pulleys.
Old 11-24-2014, 09:28 AM   #11
vrizrak
Removed belt. Not sure but looks like water pump's pulley little bit loose. Ran engine without belt and noise was gone. Nothing. Just clean engine sound. Turns out that was water pump. I'm planning to replace it this weekend. Will update after..
Old 11-24-2014, 09:39 AM   #12
bronsin
bronsin's Avatar
Excellent!
But the WP wasn't leaking?
How much was the wobble in the pulley? Did the rim of the pulley move more than like 1/8 inch?
Old 11-24-2014, 09:39 AM   #13
tmontague
tmontague's Avatar
my fiancee's wp went without leaking any fluid. The only way I knew was by a brutal noise. Most leak fluid first but not always, good advice to run without belt.
Old 11-24-2014, 10:04 AM   #14
vrizrak
Excellent!
There is no leaks. Well at least I can't find it. When I tried to move pulley I can feel a little knocking. Not very hard knocking but still and the pulley is moving not bad but enough to feel it. I checked other pulley from Alternator and AC they standing still.
Old 11-24-2014, 10:04 AM   #15
vrizrak
No noise without belt... :)
Old 11-24-2014, 12:20 PM   #16
CoryM
Glad you got it figured out. The water pump pulley should not rock at all. Some will slide in and out a SMALL amount (barely noticeable), but never rock. The bearing on the Yaris waterpump are a little weak so do not over tighten the belt when you replace the pump or you will be doing it again.
Cheers.
Old 11-24-2014, 12:26 PM   #17
vrizrak
Cheers.
I've notice belt was over tighten. That probably what kill bearing. Well I will find out when I pull it from the car. Thanks.
Old 12-02-2014, 09:49 AM   #18
vrizrak
Last weekend took water pump out for replace. It actually wasn't leaking but as you can see on picture it something. And it wasn't spinning freely. Feels like it ran over rubber or something. Anyway changed WP and not noise is gone. Except belt is squeaking when cold. :)
Weird Noise, unsure rpicard@demand-its.com DIY / Maintenance / Service 2 02-12-2013 03:52 PM
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
